查看: 1544|回复: 3
[运行时] 尝试读取或写入受保护的内存
发表于 2013-9-13 16:03:29 | 显示全部楼层 |阅读模式
  try
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                DocumentLock docLock = doc.LockDocument();
                ObjectId LastId = new ObjectId();
                string SelectId = dg_data.Rows[e.RowIndex].Cells[0].Value.ToString();
                string Rid = SelectId.Replace("(", "").Replace(")", "");
                Int64 Fid = Int64.Parse(Rid);
                IntPtr Sid = (IntPtr)Fid;
                ObjectId Id = new ObjectId(Sid);
                Database extDatabase = new Database(false,false);
                using (Transaction trans = extDatabase.TransactionManager.StartTransaction())
                    try
                        if (LastId != null)
                            Entity Ent = trans.GetObject(LastId, OpenMode.ForRead) as Entity;
                            Ent.Unhighlight();
                    catch { }
                    Entity ent = trans.GetObject(Id, OpenMode.ForRead) as Entity;
                    if (ent.GetType().Name == "Line")
                        ent.Highlight();
                        //Line line = ent as Line;
                        //if (line != null)
                        //    line.StartPoint = new Point3d(0.0,0.0,0.0);
                        //    line.EndPoint = new Point3d(0.0, 0.0, 0.0);
                    LastId = Id;
                    //ent.TransformBy(Matrix3d.Displacement(new Vector3d(0, 0, 3)));//移动整个实体
                    trans.Commit();
                docLock.Dispose();
            catch { }
红色报错  尝试读取或写入受保护的内存。这通常指示其他内存已损坏。   请高手帮忙看下~我想让实体闪烁Highlight
而且我想修改直线的 line.StartPoint = new Point3d(0.0,0.0,0.0);
不知道这样可不可以  求高手!!!
 楼主| 发表于 2013-9-13 16:29:13 | 显示全部楼层
如果有错误 请大家提出来,或者那里要改的请告诉我一下,谢谢了~
发表于 2013-9-14 07:51:23 | 显示全部楼层
这个得在环境下调试
 楼主| 发表于 2013-9-14 10:22:56 | 显示全部楼层
ps122hb 发表于 2013-9-14 07:51
这个得在环境下调试
好的 ,谢谢~
GMT+8, 2025-5-2 17:50 , Processed in 0.162878 second(s), 24 queries , Gzip On.
