楼主: 峰峰兒
[已解答] LISP
 楼主| 发表于 2013-8-15 07:44:47 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-8-15 22:16:42 | 显示全部楼层
  1. ;方法一
  2. (defun c:E22 (/ F1 F2 filename1 filename2)
  3.   (setvar "cmdecho" 0)
  4.   (setq F1 (getstring "\源文件名: "))
  5.   (setq F2 (getstring "\目标文件名: "))
  6.   (setq filename1 (strcat "C:\\DHPP2K6\" F1 ".dwg"))
  7.   (setq filename2 (strcat "C:\\DHPP2K6\" F2 ".dwg"))
  8.   (if (findfile filename1)
  9.     (progn
  10.       (if (findfile filename2)
  11.         (vl-file-delete filename2)
  12.       )
  13.       (vl-file-copy filename1 filename2)
  14.       (princ "\n指定插入点: ")
  15.       (command "-insert" filename2 "s" 1)
  16.       (while (/= 0 (getvar "cmdactive"))
  17.         (command pause)
  18.       )
  19.     )
  20.   )
  21.   (setvar "cmdecho" 1)
  22.   (princ)
  23. )
  24. ;方法二
  25. (defun c:E22 (/ F1 F2 filename1 filename2 wsh strCommand)
  26.   (setvar "cmdecho" 0)
  27.   (setq F1 (getstring "\源文件名: "))
  28.   (setq F2 (getstring "\目标文件名: "))
  29.   (setq filename1 (strcat "C:\\DHPP2K6\" F1 ".dwg"))
  30.   (setq filename2 (strcat "C:\\DHPP2K6\" F2 ".dwg"))
  31.   (if (findfile filename1)
  32.     (progn
  33.       (setq wsh (vlax-create-object "WScript.Shell"))
  34.       (setq strCommand (strcat "cmd.exe /c copy /y " filename1 " " filename2))
  35.       (vlax-invoke-method wsh 'run strCommand 0 1)
  36.       (vlax-release-object wsh)
  37.       (princ "\n指定插入点: ")
  38.       (command "-insert" filename2 "s" 1)
  39.       (while (/= 0 (getvar "cmdactive"))
  40.         (command pause)
  41.       )
  42.     )
  43.   )
  44.   (setvar "cmdecho" 1)
  45.   (princ)
  46. )
GMT+8, 2025-7-19 11:26 , Processed in 0.148406 second(s), 19 queries , Gzip On.
