查看: 3399|回复: 9
[基础教程] 利用AutoCAD自身命令绘制多段线最大内接圆
发表于 2013-8-2 18:24:21 | 显示全部楼层 |阅读模式
选择一个多段线
选择命令->偏移->通过->看到图形变成三角形时,确定
利用修剪、圆、直线命令绘制三角形内接圆圆心,同时也是多段线内接圆圆心
捕捉设置勾选垂足、切线,利用圆心、半径命令绘制多段线最大内接圆,OK!
发表于 2013-8-3 04:16:21 | 显示全部楼层
这个思路好!
 楼主| 发表于 2013-9-29 13:05:57 | 显示全部楼层
本来想多写几个,大家都不感兴趣就算了
发表于 2016-7-8 21:11:13 | 显示全部楼层
我刚看到  楼主接上
发表于 2016-7-8 21:12:26 | 显示全部楼层
我一直在找是的选多个封闭的多段线分别做内接圆
发表于 2016-7-8 21:14:26 | 显示全部楼层
;对于椭圆及SPLine可以用下面函数取点:
;; get point set of a closed curve by order
;; this function you improve by yourself acordding your need .
(defun get-closed-curve-pts (en / ent et)
  ;;by GSLS(SS)
  (setq
    ent        (entget en)
    et        (cdr (assoc 0 ent))
  (cond
    ((= et "LWPOLYLINE")
     ((lambda (/ a b vetex bu p1 p2 l r ang an1 N)
        (while (setq ent (member (assoc 10 ent) ent))
          (setq        b     (cons (cdar ent) b)
                ent   (member (assoc 42 ent) ent)
                ent   (cdr ent)
                vetex (cons b vetex)
                b     nil
        (while vetex
          (setq        a     (car vetex)
                vetex (cdr vetex)
                bu    (car a)
                p1    (cadr a)
          (if l
            (setq p2 (car l))
            (setq p2 (cadr (last vetex))
                  l  (cons p2 l)
          (if (equal bu 0 1e-6)
            (setq l (cons p1 l))
              (setq ang        (* 2 (atan bu))
                    r        (/ (distance p1 p2)
                           (* 2 (sin ang))
                    c        (polar p1
                               (+ (angle p1 p2) (- (/ pi 2) ang))
                               r
                    r        (abs r)
                    ang        (abs (* ang 2.0))
                    N        (abs (fix (/ ang 0.0174532925199433)))
              (if (= N 0)
                  (setq        an1 (/ ang N)
                        ang (angle c p2)
                  (if (not (minusp bu))
                    (setq an1 (- an1))
                  (repeat (1- N)
                    (setq ang (+ ang an1))
                    (setq l (cons (polar c ang r) l))
        l
    ((= et "CIRCLE")
     ((lambda (c R / sa ptl)
        (setq sa 0.0)
        (repeat        180
          (setq        ptl (cons (polar c sa R) ptl)
                sa  (+ sa 0.0174532925199433)
        (setq ptl (reverse ptl))
        (append
          ptl
          (mapcar (function
                    (lambda (p)
                      (mapcar (function +) c (mapcar (function -) c p))
                  ptl
       (cdr (assoc 10 ent))
       (cdr (assoc 40 ent))
    ((= et "SPLINE")
     ((lambda (/ r l _oce)
        (setq _oce (getvar "CMDECHO"))
        (setvar "CMDECHO" 0)
        (if (vl-catch-all-apply
              (function vl-cmdf)
              (list "_PEDIT"
                    (vlax-vla-object->ename
                      (vla-copy (vlax-ename->vla-object en))
                    10
            (setq l (ss-assoc 10 (entget (setq r (entlast)))))
            (if        (vlax-curve-isClosed r)
              (setq l (append l (list (car l))))
            (entdel r)
        (setvar "CMDECHO" _oce)
    ((= et "ELLIPSE")
     ((lambda (/ e l _os)
        (setq _os (getvar "OSMODE"))
        (setvar "OSMODE" 0)
        (vl-catch-all-apply
          (function vla-offset)
          (list (vlax-ename->vla-object en) 0.1)
        (setq e (entlast))
        (vl-catch-all-apply
          (list (vlax-ename->vla-object (entlast)) -0.1)
        (entdel e)
        (setq e (entlast))
        (setq l (ss-assoc 10 (entget e)))
        (entdel e)
        (setvar "OSMODE" _os)
这个的找到的单个求内接圆  请大师改成 多选后个画内接圆
发表于 2016-7-8 21:16:39 | 显示全部楼层
;max circle inside polyline
;Stefan M. 26.07.2012
(defun C:TEST ( / space e l m c o r p offtype)
  (setq space (vlax-get (vla-get-ActiveDocument (vlax-get-acad-object)) (if (= (getvar 'cvport) 1) 'PaperSpace 'ModelSpace)))
  (setq offtype (getvar 'offsetgaptype))
  (setvar 'offsetgaptype 1)
  (if (setq e (ssget ":E:S:L" '((0 . "LWPOLYLINE"))))
         (setq e         (vlax-ename->vla-object (ssname e 0))
               l         (list (vla-copy e))
               m         0.0
         (while l
            (foreach x l
               (if
                 (setq c (cond ((and
                                  (= (vlax-curve-GetEndParam x) 2.0)
                                  (or
                                    (vl-some 'zerop (mapcar '(lambda (a) (vla-getbulge x a)) '(0 1)))
                                      (distance
                                        (vlax-curve-GetPointAtParam x 0.5)
                                        (vlax-curve-GetPointAtParam x 1.5)
                                      (distance
                                        (vlax-curve-GetPointAtParam x 0.0)
                                        (vlax-curve-GetPointAtParam x 1.0)
                                 (mapcar         '(lambda (a b) (* 0.5 (+ a b)))
                                ((and
                                    (= (vlax-curve-GetEndParam x) 3.0)
                                   (vlax-curve-IsClosed x)
                                    (vl-every 'zerop (mapcar '(lambda (a) (vla-getbulge x a)) '(0 1 2)))
                                 (incircle x)
                               ((and
                                    (= (vlax-curve-GetEndParam x) 4.0)
                                   (equal '(0. 0. 0.) (mapcar '+ (vlax-curve-GetFirstDeriv x 0.5) (vlax-curve-GetFirstDeriv x 2.5)) 1e-8)
                                    (equal '(0. 0. 0.) (mapcar '+ (vlax-curve-GetFirstDeriv x 1.5) (vlax-curve-GetFirstDeriv x 3.5)) 1e-8)
                                (median x)
                                ((< (vla-get-area x) 1e-7) (median x))
                 (if
                     (equal (setq r (distance c (vlax-curve-GetClosestPointTo e c))) m 1e-8)
                     (setq p (cons (list c r) p))
                     (if (> r m) (setq p (list (list c r)) m r))
                 (setq o (append (offset_in x) o))
               (vla-delete x)
            (setq l o o nil)
         (foreach x p (vla-put-Color (vla-AddCircle space (vlax-3D-point (car x)) (cadr x)) acRed))
  (setvar 'offsetgaptype offtype)
(defun incircle (e / a b c p pt)
  (setq a (vlax-curve-GetDistAtParam e 1)
        b (- (vlax-curve-GetDistAtParam e 2) a)
        c (- (setq p (vlax-curve-GetDistAtParam e 3)) a b)
        pt (mapcar 'vlax-curve-GetPointAtParam (list e e e) '(2 3 1))
  (mapcar
    '(lambda (x) (/ (apply '+ (mapcar '* (list a b c) x)) p))
    (list
      (mapcar 'car pt)
      (mapcar 'cadr pt)
(defun median (e / i l n)
  (repeat
    (setq n (fix (setq i (vlax-curve-GetEndParam e))))
    (setq l (cons (vlax-curve-GetPointAtParam e (setq n (1- n))) l))
  (mapcar
    '(lambda (x) (/ (apply '+ x) i))
    (list
      (mapcar 'car l)
      (mapcar 'cadr l)
(defun offset_in (e / i)
   (setq i (/ (vla-get-Area e) (vla-get-Length e) 10.0))
   (apply
      'append
      (mapcar
         (function
            (lambda (x / o)
               (if
                  (not (vl-catch-all-error-p (setq o (vl-catch-all-apply 'vlax-invoke (list e 'Offset x)))))
                    (vl-remove-if
                       '(lambda (a)
                           (and
                              (or
                                 (> (vla-get-Area a) (vla-get-Area e))
                                 (> (vla-get-Length a) (vla-get-Length e))
                              (not (vla-delete a))
                       o
         (list i (- i))
这个才是
发表于 2016-7-8 21:20:58 | 显示全部楼层
请大师帮我改成 选多个封闭多段线画最大内接圆
发表于 2018-4-3 15:18:24 | 显示全部楼层
没看懂,有点小尴尬
GMT+8, 2025-5-1 16:02 , Processed in 0.189930 second(s), 28 queries , Gzip On.
