查看: 1765|回复: 2
[求助]如何获取当前dwg的名字?
发表于 2003-9-26 18:55:00 | 显示全部楼层 |阅读模式
如何获取当前dwg的名字?另外如何获取polyline实体的节点、判断是否为封闭线、判断是二维还是三维?
谢谢
发表于 2003-9-27 10:15:00 | 显示全部楼层
获取Polyline实体节点:
void readplinevertex(AcDbObjectId plineid,std::vector<AcGePoint3d> *verpt)
{//读取给定多义线ID的顶点数据,保存在verpt中
        AcDbObject *pline;
        acdbOpenObject(pline,plineid,AcDb::kForRead);
        if(pline->isKindOf(AcDb2dPolyline::desc())){
                pline->close();
                AcDb2dPolyline *pline;
                AcDbObjectIterator *piter=pline->vertexIterator();
                pline->close();
                AcDbObjectId verid;
                AcDb2dVertex *pver;
                for(long i=0;!piter->done();i++,piter->step()){
                        verid=piter->objectId();
                        acdbOpenObject(pver,verid,AcDb::kForRead);
                        verpt->push_back(pver->position());
                        pver->close();
                delete piter;
        }else if(pline->isKindOf(AcDb3dPolyline::desc())){
                pline->close();
                AcDb3dPolyline *pline;
                pline->close();
                AcDbObjectId verid;
                AcDb3dPolylineVertex *pver;
                        pver->close();
                delete piter;
        }else{//AcDbPolyline Object
                pline->close();
                AcDbPolyline *pline;
                AcGePoint3d pt;
                for(long i=0;i<pline->numVerts();i++){
                        pline->getPointAt(i,pt);
                        verpt->push_back(pt);
                pline->close();
上面函数中本身已包含2D合3D的判断。
判断是否封闭:
  acdbOpenObject(pline,objid,AcDb::kForRead);
  if(pline->isClosed()==Adesk::kTrue)//是否封闭多义线
pline->close();
 楼主| 发表于 2003-9-27 13:17:00 | 显示全部楼层
谢谢!还有一个问题是3d、2d polyline如何判断其是否封闭,isclosed是判断acdbpolyline的
GMT+8, 2025-5-12 05:32 , Processed in 0.154852 second(s), 24 queries , Gzip On.
