查看: 7448|回复: 10
[原创]反转多段线
发表于 2003-9-15 20:54:00 | 显示全部楼层 |阅读模式
多段线有起始端和终止端,以下程序是将起始端和终止端对调过来,而在多段线的外观上没有变化。
  1. Sub RevPline()
  2.     Dim ent As AcadEntity
  3.     Dim pnt As Variant
  4.     Dim NewCoord() As Double
  5.     Dim i As Integer
  6.     On Error Resume Next
  7.     Do
  8.         ThisDrawing.Utility.GetEntity ent, pnt, "选择多段线:"
  9.         If Err Then Exit Sub
  10.         If TypeName(ent) Like "IAcad*Polyline" Then Exit Do
  11.     Loop
  12.     Dim Coord As Variant
  13.     If TypeName(ent) = "IAcadLWPolyline" Then
  14.         Coord = ent.Coordinates
  15.         ReDim NewCoord(UBound(Coord)) As Double
  16.         For i = 0 To UBound(Coord) - 1 Step 2
  17.             NewCoord(UBound(Coord) - i - 1) = Coord(i)
  18.             NewCoord(UBound(Coord) - i) = Coord(i + 1)
  19.         Next
  20.         ent.Coordinates = NewCoord
  21.         ThisDrawing.Regen acActiveViewport
  22.     ElseIf TypeName(ent) = "IAcadPolyline" Then
  23.         Coord = ent.Coordinates
  24.         ReDim NewCoord(UBound(Coord)) As Double
  25.         For i = 0 To UBound(Coord) - 1 Step 3
  26.             NewCoord(UBound(Coord) - i - 2) = Coord(i)
  27.             NewCoord(UBound(Coord) - i - 1) = Coord(i + 1)
  28.             NewCoord(UBound(Coord) - i) = Coord(i + 2)
  29.         Next
  30.         ent.Coordinates = NewCoord
  31.         ThisDrawing.Regen acActiveViewport
  32.     End If
  33.
  34. End Sub
发表于 2003-9-16 18:07:00 | 显示全部楼层
这个程序非常好用,如果再可以处理多段线中的圆弧就更好了!
 楼主| 发表于 2003-9-16 19:29:00 | 显示全部楼层
好,那就增加凸度的处理:
  1. Sub RevPline()
  5.     Dim i As Integer
  7.     Do
  11.     Loop
  13.     Dim CoordCount As Integer
  14.     Dim Bulge() As Double
  15.     If TypeName(ent) = "IAcadLWPolyline" Then
  16.         Coord = ent.Coordinates
  17.         CoordCount = (UBound(Coord) + 1) / 2
  18.         ReDim NewCoord(UBound(Coord)) As Double
  19.         For i = 0 To UBound(Coord) - 1 Step 2
  20.             NewCoord(UBound(Coord) - i - 1) = Coord(i)
  21.             NewCoord(UBound(Coord) - i) = Coord(i + 1)
  22.         Next
  23.         ReDim Bulge(CoordCount - 1) As Double
  24.         For i = 0 To CoordCount - 1
  25.             Bulge(i) = ent.GetBulge(i)
  26.         Next
  27.         ent.Coordinates = NewCoord
  28.         For i = 0 To CoordCount - 2
  29.             ent.SetBulge i, -Bulge(CoordCount - 2 - i)
  30.         Next
  32.     ElseIf TypeName(ent) = "IAcadPolyline" Then
  33.         Coord = ent.Coordinates
  34.         CoordCount = (UBound(Coord) + 1) / 3
  35.         ReDim NewCoord(UBound(Coord)) As Double
  36.         For i = 0 To UBound(Coord) - 1 Step 3
  37.             NewCoord(UBound(Coord) - i - 2) = Coord(i)
  38.             NewCoord(UBound(Coord) - i - 1) = Coord(i + 1)
  39.             NewCoord(UBound(Coord) - i) = Coord(i + 2)
  40.         Next
  41.         If ent.Type = acSimplePoly Then
  42.             ReDim Bulge(CoordCount - 1) As Double
  43.             For i = 0 To CoordCount - 1
  44.                 Bulge(i) = ent.GetBulge(i)
  45.             Next
  46.         End If
  47.         ent.Coordinates = NewCoord
  48.         If ent.Type = acSimplePoly Then
  49.             For i = 0 To CoordCount - 2
  50.                 ent.SetBulge i, -Bulge(CoordCount - 2 - i)
  51.             Next
  52.         End If
  53.        ThisDrawing.Regen acActiveViewport
  54.     End If
  55.
  56. End Sub
发表于 2003-9-18 01:37:00 | 显示全部楼层
太好用了!!MCCAD辛苦了!!
发表于 2004-9-23 11:57:00 | 显示全部楼层
那么我们怎么判断其方向是顺时针还是逆时针呢?
发表于 2004-9-23 14:21:00 | 显示全部楼层
在VLISP版块里有用VLISP写了一个"曲线反向"的程序.
发表于 2009-11-28 16:34:00 | 显示全部楼层
不能查看呢???
发表于 2009-11-28 20:57:00 | 显示全部楼层
在这里留言,怎么经常出错,太郁闷了,刚打好的字儿,没了
发表于 2014-5-3 23:11:27 | 显示全部楼层
好贴bc标记
发表于 2014-5-6 15:32:27 | 显示全部楼层
NICE!谢楼主
楼主大神,能提供一个多段线端点三维坐标的程序吗?给点提示也成!我比较小白。要是带Z坐标的哦
GMT+8, 2025-5-26 08:58 , Processed in 0.182938 second(s), 22 queries , Gzip On.
