楼主: mccad
[2014] AutoCAD 出现“安全系统(软件锁许可管理器)不起作用或未正确安装”的解决方法
发表于 2019-4-29 09:58:50 | 显示全部楼层
Reactivate the license:
Be sure that files and folders are not hidden using these instructions.
  • Remove all files under C:\Users\<username>\AppData\Roaming\Autodesk\ADUT
  • Remove all files under C:\ProgramData\Autodesk\ADUT
  • Go to C:\ProgramData\Autodesk\CLM and delete the folder "LGS"
  • Go to C:\ProgramData\FLEXnet and delete all files that start with adskflex
  • Go to C:\Users\<username>\AppData\Local\Autodesk\Web Services and delete the file LoginState.xml
  • Start AutoCAD again.
发表于 2019-4-29 23:21:42 | 显示全部楼层
碉堡了,谢谢
GMT+8, 2025-5-18 07:45 , Processed in 0.138183 second(s), 17 queries , Gzip On.
