楼主: a280881620
vba怎么实现修改指定图层的线宽和文字高度
发表于 2014-4-9 22:11:35 | 显示全部楼层
试试这个
  1. Sub test()
  2.     '将DLSS层上所有多段线的全局宽度改为0
  3.     On Error Resume Next
  4.
  5.     Dim Ssd As AcadSelectionSet
  6.     Dim FType(0 To 1) As Integer
  7.     Dim FData(0 To 1) As Variant
  8.     Dim TeObj As Object
  9.
  10.     FType(0) = 0
  11.     FType(1) = 8
  12.
  13.     FData(0) = "LWPOLYLINE"
  14.     FData(1) = "DLSS"
  15.
  16.     ThisDrawing.SelectionSets("Ssd").Delete
  17.
  18.     '创建选择集(选择图层为DLSS,图元实体为文字的选择集)
  19.     Set Ssd = ThisDrawing.SelectionSets.Add("Ssd")
  20.     Ssd.Select acSelectionSetAll, , , FType, FData
  21.     For Each TeObj In Ssd
  22.         TeObj.ConstantWidth = 0
  23.     Next
  24.
  25. End Sub
GMT+8, 2025-5-1 14:08 , Processed in 0.144177 second(s), 17 queries , Gzip On.
