- 积分
- 10329
- 明经币
- 个
- 注册时间
- 2006-6-28
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2014-7-24 20:58:45
显示全部楼层
(defun cutnum_lst (oldlst num / k templst)
(setq k 0
templst '()
(foreach n oldlst
(if (/= k num)
(setq templst (cons n templst)
k (1+ k)
(setq k (1+ k))
(setq newlst (reverse templst))
;;去除表中指定项
(defun drop (lst item)
(append (reverse (cdr (member item (reverse lst))))
(cdr (member item lst))
;;将点表中在方框内的点组成新表
(defun pt_inm (oldlst PT1 PT2 PT3 PT4 / oldlist n pt1 pt2 pt3 pt4
templst newlst)
(setq templst '())
(foreach n oldlst
(if (/= (point_inm n pt1 pt2 pt3 pt4) nil)
(setq templst (cons n templst))
;;将点表中在多边形内的点组成新表
(defun pt_inmx (oldlst pm)
(setq templst '())
(foreach n oldlst
(if (ea:point_inm n pm)
;;判断两点是否等
(defun eq_point (pt1 pt2)
(if (and (equal (car pt1) (car pt2) 1e-5)
(equal (cadr pt1) (cadr pt2) 1e-5)
t
nil
;;判断两直线是否相交
(defun line_int (se1 se2)
(if (/= (inters (cdr (assoc 10 (entget se1)))
(cdr (assoc 11 (entget se1)))
(cdr (assoc 10 (entget se2)))
(cdr (assoc 11 (entget se2)))
t
nil
t
nil
;;点到直线的垂直距离
(defun point_line (pt pt1 pt2 / ptangle ptn pt pt1 pt2 dist jptx)
(setq ptangle (angle pt1 pt2)
ptn (polar pt (+ (* 0.5 pi) ptangle) 0.01)
jptx (inters pt ptn pt1 pt2 nil)
dist (distance pt jptx)
dist
;;判断点是否在方框内
(defun point_inm (pt pt1 pt2 pt3 pt4 / dist1 dist2 dist3 dist4 pt pt1
pt2 pr3 pt4)
(setq dist1 (point_line pt pt1 pt2)
dist2 (point_line pt pt2 pt3)
dist3 (point_line pt pt1 pt4)
dist4 (point_line pt pt3 pt4)
(if (equal (+ dist1 dist2 dist3 dist4)
(+ (distance pt1 pt2) (distance pt2 pt3))
1e-10
t
nil
;;测试点是否在多边形内.
(defun ea:point_inm
(p pm / point_x mx px1 pm edge_int_num pt_online_num)
(setq point_x (mapcar '(lambda (x) (car x)) pm)
mx (abs (- (apply 'max point_x) (car p)))
px1 (polar p 0 (* mx 2))
(setq pm (append pm (list (nth 0 pm)))
edge_int_num 0
pt_online_num 0
(while (> (length pm) 1)
(setq pc (nth 0 pm)
pn (nth 1 pm)
(if (inters p px1 pc pn)
(setq edge_int_num (+ 1 edge_int_num))
(if (equal (angle p pc) 0 1e-5)
(setq pt_online_num (+ 1 pt_online_num))
(if (and (equal (angle p pc) 0 1e-5)
(equal (angle p pn) 0 1e-5)
(setq pt_online_num (- pt_online_num 1))
(setq pm (cdr pm))
(if (= (rem (+ pt_online_num edge_int_num) 2) 1)
t
nil
;;清理表中的重复项
(defun purge_lst (lst / n m lst1 tmplist)
(setq tmplist '()
tmplist (cons (car lst) tmplist)
lsttmp (cutnum_lst lst 0)
(setq n (length lsttmp)
m 0
(while (/= m n)
(setq id '()
lst1 (nth m lsttmp)
(foreach na tmplist
(if (= (eq_point na lst1) nil)
(setq id (cons 0 id))
(setq id (cons 1 id))
(if (= (member '1 id) nil)
(setq tmplist (cons lst1 tmplist))
(setq m (1+ m))
(setq tmplist (reverse tmplist))
;;计算两点的中点
(defun mpt (mpt1 mpt2)
(polar mpt1 (angle mpt1 mpt2) (/ (distance mpt1 mpt2) 2))
(defun se_426 (pt)
(setq sex1 (ssname (ssget "c" pt pt) 0)
sex1ent (entget sex1)
sex1name (cdr (assoc -1 sex1ent))
sex1pt1 (cdr (assoc 10 sex1ent))
sex1pt2 (cdr (assoc 11 sex1ent))
newse (drop selist sex1name)
newsen (length newse)
newsem 0
newjptlist '()
(while (/= newsem newsen)
(setq newse1 (nth newsem newse)
newsept1 (cdr (assoc 10 (entget newse1)))
newsept2 (cdr (assoc 11 (entget newse1)))
(if
(setq newjpt1 (inters sex1pt1 sex1pt2 newsept1 newsept2))
(setq newjptlist (cons newjpt1 newjptlist))
(setq newsem (1+ newsem))
(setq newjptx (car newjptlist)
newjpty (cadr newjptlist)
(if (> (distance newjptx pt) (distance newjpty pt))
(setq newjpt newjptx)
(setq newjpt newjpty)
(command "break" sex1 newjpt pt)
(defun se_123 (lst)
(setq se1 lst)
(setq dptx (cdr (assoc 10 (entget se1)))
dpty (cdr (assoc 11 (entget se1)))
(if (or (equal dptlist (list dptx dpty))
(equal dptlist (list dpty dptx))
(command "erase" se1 "")
;;; 主程序
(defun c:ttr (/ pta ptb ptax ptay ptbx ptby
ptaxby ptbxay ptbox se n m nn
mm nnn mmm ptlist ptl lse sename
pt1 pt2 pt3 pt4 ptlist1 n1 m1
ptl tmplist templist na nb nab
ptl3 ptl4 jpt1 jpt2 jpt3 jpt4 se1
jptx jpty dptx dpty sex1 sex1net sex1name
sex1pt1 sex1pt2 newse newsen newsem newjptlist
newsept1 newsept2 newjpt1 newjpt2 newjptx
newjpty dpt1 dpt2 dpt3 dpt4 se2 se3
sef2 ent1 ent2 p1 p2 p3 p4 ipts se2com entlst2
(setq cadver (substr (getvar "acadver") 1 2))
(setq oldos (getvar "osmode"))
(if (< oldos 16384)
(setvar "osmode" (+ oldos 16384))
(setq oldcmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(or sk_frad (setq sk_frad 0.0));;;设置sk_frad为全局变量
(if (setq sk_fr(getreal (strcat "\n请输入圆角半径<" (rtos sk_frad 2 2) ">:")))(setq sk_frad sk_fr))
(prompt "\n请选择修剪区域,直接选取(左键)为窗选,右键为栅选<任意键结束>:")
;(if (= cadver "14")
;(setq pta (grread (grread)))
(setq pta (grread))
(while (/= (car pta) 2)
(if (and (/= (car pta) 12)(listp (cadr pta)))
(setq pta (cadr pta))
(setq ptb (getcorner pta "\n修剪区域对角:"))
(if (/= ptb nil)
(setq ptax (car pta)
ptay (cadr pta)
ptbx (car ptb)
ptby (cadr ptb)
(setq ptaxby (list ptax ptby)
ptbxay (list ptbx ptay)
(setq sebox (list pta ptaxby ptb ptbxay))
(setq se (ssget "c" pta ptb '((0 . "LINE"))))
(setq se nil)
(if (or (= (car pta) 12)(= (car pta) 25))
(SETQ PTA (CAR PTA))
(setq sebox '())
(setq aa (getpoint "\n选取多边形区域的一个顶点"))
(if (/= aa nil)
(setq sebox (cons aa sebox))
(setq dd aa)
(while
(setq cc (getpoint aa "\n选取多边形区域的下一顶点"))
(grdraw aa cc 7 1)
(setq aa cc)
(grdraw aa dd 7 1)
(setq se (ssget "cp" sebox '((0 . "LINE"))))
(redraw)
(setq se nil)
(IF (/= SE NIL)
(PROGN
(SETQ n (sslength se)
selist '()
ptl '()
ptlist '()
m 0
(while (/= m n)
(setq lse (entget (ssname se m))
sename (cdr (assoc -1 lse))
selist (cons sename selist)
pt1 (cdr (assoc 10 lse))
pt2 (cdr (assoc 11 lse))
ptl (cons pt2 ptl)
ptl (cons pt1 ptl)
ptlist (cons ptl ptlist)
ptl '()
m (1+ m)
(setq n (length ptlist)
m 0
jptlist '()
(while (/= m n)
(setq ptl1 (car (nth m ptlist))
ptl2 (cadr (nth m ptlist))
ptlist1 (cutnum_lst ptlist m)
m (1+ m)
n1 (length ptlist1)
m1 0
(while (/= m1 n1)
(setq ptl3 (car (nth m1 ptlist1))
ptl4 (cadr (nth m1 ptlist1))
(if (setq jpt (inters ptl1 ptl2 ptl3 ptl4 t))
(setq jptlist (cons jpt jptlist))
(setq m1 (1+ m1))
(setq jptlist (purge_lst jptlist))
(setq tmptlist '()
n (length ptlist)
m 0
(while (/= m n)
(setq dpt1 (car (nth m ptlist))
tmptlist (cons dpt1 tmptlist)
dpt2 (cadr (nth m ptlist))
tmptlist (cons dpt2 tmptlist)
m (1+ m)
(setq dptlist (reverse tmptlist))
(if (listp pta)
(if (= (equal jptlist '(nil)) nil)
(setq jptlist (pt_inm jptlist pta ptbxay ptb ptaxby)
(setq dptlist (pt_inm dptlist pta ptbxay ptb ptaxby)
(setq jptlist (pt_inmx jptlist sebox))
(setq dptlist (pt_inmx dptlist sebox)
(if (/= dptlist nil)
(setq dptlist (purge_lst dptlist))
(if (equal jptlist '(nil))
(setq na 0)
(setq na (length jptlist))
(setq nb (length dptlist)
nab (+ na nb)
nlist (list na nb nab)
;;;执行操作
(if (equal nlist '(2 0 2))
(command "trim"
se
(mpt (car jptlist) (cadr jptlist))
(if (equal nlist '(4 8 12))
(command "trim"
se
(car dptlist)
(cadr dptlist)
(caddr dptlist)
(cadddr dptlist)
(cadddr (cdr dptlist))
(cadddr (cddr dptlist))
(cadddr (cdddr dptlist))
(cadddr (cdddr (cdr dptlist)))
(if (and (= (* 2 (length selist)) nb) (= na 0))
(command "ERASE" se "")
(if
(and (= na 0) (= (- (length selist) (length dptlist)) 1))
(setq n (length dptlist)
m 0
(while (/= m n)
(setq dpt (nth m dptlist))
(setq m (1+ m))
(command "EXTEND" se "" dpt "")
(setq yorn (getstring "\n需要修剪吗?Y or N <Y>"))
(if (or (= yorn "y") (= yorn "") (= yorn nil))
(setq jptxlist '())
(setq n (length selist)
m 0
(while (/= m n)
(setq sexx (nth m selist))
(setq sexlist (cutnum_lst selist m))
(setq nn (length sexlist)
mm 0
(while (/= mm nn)
(setq sexy (nth mm sexlist))
(if (setq
jptx
(inters (cdr (assoc 10 (entget sexx)))
(cdr (assoc 11 (entget sexx)))
(cdr (assoc 10 (entget sexy)))
(cdr (assoc 11 (entget sexy)))
(setq jptxlist (cons jptx jptxlist))
(setq mm (1+ mm))
(setq m (1+ m))
(setq jptxlist (purge_lst jptxlist))
(while (>= (length jptxlist) 2)
(setq jptx1 (nth 0 jptxlist)
jptx2 (nth 1 jptxlist)
(command "trim"
se
(mpt jptx1 jptx2)
(setq jptxlist (cdr jptxlist))
(if (equal nlist '(4 0 4))
(setq jpt1 (car jptlist)
jpt2 (cadr jptlist)
jpt3 (caddr jptlist)
jpt4 (cadddr jptlist)
(cond
((= (ssget (mpt jpt1 jpt2)) nil)
(command "trim"
se
(mpt jpt1 jpt3)
(mpt jpt1 jpt4)
(mpt jpt2 jpt3)
(mpt jpt2 jpt4)
((= (ssget (mpt jpt1 jpt3))nil)
(command "trim"
se
(mpt jpt1 jpt2)
(mpt jpt1 jpt4)
(mpt jpt2 jpt3)
(mpt jpt3 jpt4)
((= (ssget (mpt jpt1 jpt4))nil)
(command "trim"
se
(mpt jpt1 jpt2)
(mpt jpt1 jpt3)
(mpt jpt2 jpt4)
(mpt jpt3 jpt4)
(if (equal nlist '(1 2 3))
(se_123 (car selist))
(se_123 (cadr selist))
(command "trim" se "" (car dptlist) (cadr dptlist) "")
(if (equal nlist '(2 2 4))
(se_123 (caddr selist))
(command "trim"
se
(car dptlist)
(cadr dptlist)
(if (equal nlist '(4 2 6))
(setq dpt1 (car dptlist)
dpt2 (cadr dptlist)
(se_426 dpt1)
(setq newjptn newjpt)
(se_426 dpt2)
(command "trim" se "" (mpt newjptn newjpt) "")
(if (and (= (length selist) 2) (equal nlist '(0 2 2)))
(command "FILLET" (car dptlist) (cadr dptlist))
(if (equal nlist '(1 1 2))
(command "trim" se "" (car dptlist) "")
(if (and (= (length selist) 2) (equal nlist '(1 3 4)))
(if (and (= (length selist) 4)
(or (equal nlist '(1 3 4)) (equal nlist '(1 4 5)))
(setq sen (length selist)
sem 0
(while (/= sem sen)
(setq sex1 (nth sem selist))
(setq newselist (drop selist sex1))
(foreach n newselist
(if (line_int sex1 n)
(setq sexa sex1
sexb n
(setq sem (1+ sem))
(setq newselist (drop selist sexa)
newselist (drop newselist sexb)
(if (listp pta)
(if
(= (point_inm
(setq
fpt1
(cdr (assoc 10 (entget (car newselist)))
pta
ptbxay
ptb
ptaxby
nil
(setq
fpt1 (cdr (assoc 11 (entget (car newselist))))
(if
(= (point_inm
(setq fpt2
(cdr (assoc 10 (entget (cadr newselist))))
pta
ptbxay
ptb
ptaxby
nil
(setq fpt2
(cdr (assoc 11 (entget (cadr newselist))))
(if
(= (ea:point_inm
(setq
fpt1
sebox
nil
(setq
(if (= (ea:point_inm
(setq
fpt2
sebox
nil
(setq fpt2
(setq oldfillet (getvar "filletrad"))
(setvar "filletrad" 10.0)
(command "FILLET" fpt1 fpt2)
(setvar "filletrad" oldfillet)
(setq dptlist1 (drop dptlist fpt1)
dptlist1 (drop dptlist1 fpt2)
(command "trim" se "" (car dptlist1) (cadr dptlist1) "")
(princ nlist)
(setvar "osmode" 4791)
(setq old (getvar "osmode"))
(if(setq sef2 (ssget "cp" sebox '((0 . "LINE"))))
(setq se2lst (ss2lst sef2))
(setq se2com (combination se2lst 2)
entlst2 '())
(while (setq ent1(car se2com))
(setq p1 (sk_dxf (car ent1) 10 )
p2 (sk_dxf (car ent1) 11 )
p3 (sk_dxf (cadr ent1) 10 )
p4 (sk_dxf (cadr ent1) 11 )
ipts(inters p1 p2 p3 p4))
(if ipts(setq entlst2(cons ent1 entlst2)))
(setq se2com(cdr se2com))
(setq entlst2(reverse entlst2))
(if (/= entlst2 '())
(setvar "filletrad" sk_frad)
(while (setq ent2(car entlst2))
(command "FILLET" (car ent2)(cadr ent2))
(setq entlst2(cdr entlst2))
(prompt "\n请选择修剪区域,直接选取为窗选,右键为栅选<任意键结束>:")
(setq pta (grread))
(setvar "osmode" oldos)
(setvar "cmdecho" oldcmd)
(PRINC
"\n智能剪程序已经加载成功,用“TTR”命令运行。"
;;选择集转表
(defun ss2lst(ss / en lst)
(if (= (type ss) 'PICKSET)
(setq lst '())
(while (setq en (ssname ss 0))
(setq lst(cons en lst))
(setq ss(ssdel en ss))
(setq lst(reverse lst))
;;;组合函数
(defun combination (lst m)
(cond ((zerop m) '(()))
((null lst) '())
(T
(append (mapcar '(lambda (y) (cons (car lst) y))
(combination (cdr lst) (- m 1))
(combination (cdr lst) m)
;;;组码值提取(sk_dxf 图元名 组码)
(defun sk_dxf(en code)
(if(and(=(type en) 'ENAME)(= (type code) 'INT))
(cdr(assoc code (entget en))))
(PRINC) |
