楼主: 半听可乐
求框选图元,根据图元类型进入不同图层
发表于 2013-5-20 21:40:49 | 显示全部楼层
  1. ;图元归层 明经 ZZXXQQ 2013.5.20 改
  2. (defun c:ly ()
  3. (setvar "CMDECHO" 0)
  4. (if (and (princ "\n选择图元: ")
  5.           (setq ss (ssget '((0 . "CIRCLE,LINE,*POLYLINE,DIMENDION,*TEXT,INSERT"))))
  6.           (setq wei (getstring "\n层名尾号: "))) (progn
  7.   (if (setq ss1 (ssget "P" '((0 . "CIRCLE"))))
  8.    (command "_.CHPROP" ss1 "" "LA" (strcat "立管层" wei) "")
  9.   )
  10.   (command "_.SELECT" ss "R" ss1 "")
  11.   (if (setq ss1 (ssget "P" '((0 . "LINE"))))
  12.    (command "_.CHPROP" ss1 "" "LA" (strcat "管道层" wei) "")
  13.   )
  14.   (command "_.SELECT" ss "R" ss1 "")
  15.   (if (setq ss1 (ssget "P" '((0 . "*POLYLINE,DIMENSION,*TEXT"))))
  16.    (command "_.CHPROP" ss1 "" "LA" (strcat "标注层" wei) "")
  17.   )
  18.   (command "_.SELECT" ss "R" ss1 "")
  19.   (if (setq ss1 (ssget "P" '((0 . "INSERT"))))
  20.    (command "_.CHPROP" ss1 "" "LA" (strcat "图块层" wei) "")
  21.   )
  22. ))
  23. (setvar "CMDECHO" 1)
  24. (princ)
  25. )
半听可乐 + 1 很给力!
发表于 2013-5-20 22:22:13 | 显示全部楼层
ZZXXQQ 发表于 2013-5-20 21:40
这个不错,顶一个!
 楼主| 发表于 2013-5-20 22:45:09 | 显示全部楼层
我照着您这个程序去改第一个程序如下:(想实现框选+点选,且选择和输命令不分先后)
(defun c:LY1  ()
   (command "_.CHPROP" ss1 "" "LA" "SXSTK" "")
   (command "_.CHPROP" ss1 "" "LA" "SX_X" "")
  (if (setq ss1 (ssget "P" '((0 . "*POLYLINE,DIMENSION,*TEXT,LEADER"))))
   (command "_.CHPROP" ss1 "" "LA" "SXDIM" "")
   (command "_.CHPROP" ss1 "" "LA" "SXBLK" "")
效果是实现了,但是为什么会有这个提示呢?感觉看着不舒服:
未知命令“LY1”。按 F1 查看帮助。
发表于 2013-6-12 12:48:53 | 显示全部楼层
为什么选不了尺寸呢!!
发表于 2014-12-23 22:19:35 | 显示全部楼层
感觉这个实用性还是不错
发表于 2015-9-13 08:55:08 | 显示全部楼层
(defun c:LY1  ()
吸取了点精华!谢谢!!
GMT+8, 2025-5-2 13:28 , Processed in 0.175439 second(s), 17 queries , Gzip On.
