查看: 7397|回复: 25
求框选图元,根据图元类型进入不同图层
发表于 2013-5-11 09:42:41 | 显示全部楼层 |阅读模式
10明经币
想把图层不规范的图纸整理一下,便于图层管理,
希望框选(同时也能点选)图元,判断图元的类型,不同的类型变到不同的图层(图中已经存在需要的图层),图元的颜色等随层:
圆-------立管层
直线------- 管道层
单多行文字、PL线、引线、线性或对齐标注 ------- 标注层
图块-------图块层
-------------------------------作为外行,我设想程序大致结构如下-----------------------------------------
(defun c:ly1 ();;所选图元分别进入后面所列图层  (立管层1,管道层1,标注层1,图块层1)
(defun c:ly2 ();;所选图元分别进入后面所列图层   (立管层2,管道层2,标注层2,图块层2)
(defun c:ly3 ();;所选图元分别进入后面所列图层   (立管层3,管道层3,标注层3,图块层3)
不知道我说清楚了没,求之若渴,盼各位热心的大侠拔刀相助!
帖子已经转到编程申请板块,编程零基础,特此申请
http://bbs.mjtd.com/thread-101385-1-1.html
最佳答案
发表于 2013-5-11 09:42:42 | 显示全部楼层
  1. ;框选图元归层 明经 ZZXXQQ 2013.5.12 汶川地震五周年
  2. (defun c:ly1 ()
  3. (setvar "CMDECHO" 0)
  4. (if (and (setq pt1 (getpoint "\n框选第一角点: "))
  5. (setq pt2 (getcorner pt1 "\n框选第二角点: "))) (progn
  6.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "CIRCLE"))))
  7.    (command "_.CHPROP" ss "" "LA" "立管层1" "")
  8.   )
  9.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "LINE"))))
  10.    (command "_.CHPROP" ss "" "LA" "管道层1" "")
  11.   )
  12.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "*POLYLINE,DIMENSION,*TEXT"))))
  13.    (command "_.CHPROP" ss "" "LA" "标注层1" "")
  14.   )
  15.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "INSERT"))))
  16.    (command "_.CHPROP" ss "" "LA" "图块层1" "")
  17.   )
  18. ))
  19. (setvar "CMDECHO" 1)
  20. (princ)
  21. )
  1. ;这个是通用函数
  2. (defun c:ly ()
  6. (setq wei (getstring "\n层名尾号: "))) (progn
  7.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "CIRCLE"))))
  8.    (command "_.CHPROP" ss "" "LA" (strcat "立管层" wei) "")
  9.   )
  10.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "LINE"))))
  11.    (command "_.CHPROP" ss "" "LA" (strcat "管道层" wei) "")
  12.   )
  13.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "*POLYLINE,DIMENSION,*TEXT"))))
  14.    (command "_.CHPROP" ss "" "LA" (strcat "标注层" wei) "")
  15.   )
  16.   (if (setq ss (ssget "W" pt1 pt2 '((0 . "INSERT"))))
  17.    (command "_.CHPROP" ss "" "LA" (strcat "图块层" wei) "")
  18.   )
  19. ))
  20. (setvar "CMDECHO" 1)
  21. (princ)
  22. )
发表于 2013-5-11 12:06:01 | 显示全部楼层
这个应该好做
发表于 2013-5-11 12:25:02 来自手机 | 显示全部楼层
这个自己尝试写下,无非就是dxf组码筛选改层
 楼主| 发表于 2013-5-11 13:11:40 | 显示全部楼层
如果会肯定自己弄了~~
发表于 2013-5-11 13:36:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2013-5-11 16:01:02 | 显示全部楼层
各种观望不出手啊?
发表于 2013-5-11 17:17:57 | 显示全部楼层
自己写写更健康
 楼主| 发表于 2013-5-11 19:45:36 | 显示全部楼层
你们不能这样啊~
发表于 2013-5-12 03:26:10 | 显示全部楼层
(Defun c:j1 ()
(Sets Ss (ssget ":L" '((0 . "Circle")));建选择集
(command "_chprop" Ss "" "la" "立管层" "");改图层
供你 参考!其他类似!
半听可乐 + 1 好久不见,感谢关注!
GMT+8, 2025-5-1 12:27 , Processed in 0.178734 second(s), 23 queries , Gzip On.
