帖子
查看: 1055|回复: 0
Select Case d2
发表于 2013-5-3 20:03:33 | 显示全部楼层 |阅读模式
Option Explicit                             '设置显式变量声明
Private CurrentDir As String                '建立模块级私有变量,存放当前路径
Private Sub Form_Load()
Dim con As ADODB.Connection                 '定义变量
Dim rst As ADODB.Recordset
Dim strcon As String
CurrentDir = CurDir("")                     '获取当前路径
strcon = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + CurrentDir + "\衬套.mdb;Persist Security Info=False"  '数据链接属性字符串
Set con = New ADODB.Connection              '建立con对象
con.Open strcon                             '打开数据库
Set rst = New ADODB.Recordset               '建立rst对象
rst.CursorLocation = adUseClient
rst.Open "select*from chentao", con, adOpenStatic, adLockBatchOptimistic '打开名为“chentao”的表
End Sub
Private Sub Command1_Click()                '单击Command1按钮时执行程序
Dim swApp As Object                         '定义变量
Dim Part As Object
Dim strfilename As String
Dim boolstatus As Boolean
Dim longstatus As Long
Dim d1 As Integer
Dim d2 As Integer
Dim h As Integer
Dim c As Single
Dim c1 As Single
Dim c2 As Single
Form1.Hide                                  '隐藏界面
d1 = Text1.Text                             '对参数赋值
d2 = Text2.Text
h = Text3.Text
c = Text4.Text
c1 = Text5.Text
c2 = Text6.Text
strfilename = CurrentDir + "\" + "衬套.SLDPRT"
Set swApp = CreateObject("SldWorks.Application")        '创建SldWorks对象
swApp.Visible = True                       '设置显示SolidWorks程序界面
Set Part = swApp.opendoc6(strfilename, 1, 0, "", longstatus, longstatus)  '打开作为模板的零件
Set Part = swApp.ActiveDoc                 '激活文件
strfilename = "衬套.SLDPRT"
longstatus = Part.Parameter("d1@草图1@strfilename").SetSystemValue3(d1 / 1000, 1, "默认")
longstatus = Part.Parameter("d2@草图1@strfilename").SetSystemValue3(d2 / 1000, 1, "默认")
longstatus = Part.Parameter("d1@拉伸1@strfilename").SetSystemValue3(h / 1000, 1, "默认")
longstatus = Part.Parameter("d1@倒角1@strfilename").SetSystemValue3(c / 1000, 1, "默认")
longstatus = Part.Parameter("d1@倒角2@strfilename").SetSystemValue3(c1 / 1000, 1, "默认")
longstatus = Part.Parameter("d1@倒角3@strfilename").SetSystemValue3(c2 / 1000, 1, "默认")          '将参数值赋予零件,生成所需模型
Select Case d2
Case 11 To 18
longstatus = Part.Parameter("d1@倒角4@strfilename").SetSystemValue3(0.8 / 1000, 1, "默认")
Case 19 To 30
longstatus = Part.Parameter("d1@倒角4@strfilename").SetSystemValue3(1 / 1000, 1, "默认")
Case 31 To 50
longstatus = Part.Parameter("d1@倒角4@strfilename").SetSystemValue3(1.6 / 1000, 1, "默认")
Case 51 To 80
longstatus = Part.Parameter("d1@倒角4@strfilename").SetSystemValue3(2 / 1000, 1, "默认")
Case 81 To 120
longstatus = Part.Parameter("d1@倒角4@strfilename").SetSystemValue3(2.5 / 1000, 1, "默认")
Case 121 To 180
longstatus = Part.Parameter("d1@倒角4@strfilename").SetSystemValue3(3 / 1000, 1, "默认")
End Select                                '根据未注倒角规定确定倒角值
boolstatus = Part.EditRebuild3()          '重建模型
Part.ShowNamedView2 "*等轴测", 7          '等轴测显示模型
Part.ViewZoomtofit2                       '自动缩放整屏显示全图
Form1.Show                                '显示界面
End Sub
求解释 select case d2 到 end select 那段的意思
GMT+8, 2025-7-6 15:05 , Processed in 0.235202 second(s), 23 queries , Gzip On.
