查看: 11765|回复: 27
谁能仿写一个“给图中的BLOCK添加遮罩”
发表于 2013-5-2 15:51:00 | 显示全部楼层 |阅读模式
10明经币
http://www.xdcad.net/forum/thread-667983-1-1.html
这里有这个帖,不过加载xdrx_api,还只能用于2004-2006 有没有高手也仿着写一个
最佳答案
发表于 2013-5-2 15:51:01 | 显示全部楼层
朽木大师 发表于 2013-5-15 13:30
来明经只是偶尔找一个小工具,说实在,对程序基本上是一无所知
  1. (defun c:tt (/ E EL NAME BLKDEF DOC OBJS LL UR MINS MAXS WIPE NEWOBJS)
  2.   (while
  3.     (and (setq e (car (entsel "\nSelect Insert:")))
  4.          (= "INSERT" (cdr (assoc 0 (setq el (entget e)))))
  5.     )
  6.      (setq name (cdr (assoc 2 el)))
  7.      (setq blkdef (vla-item
  8.                     (vla-get-blocks
  9.                       (setq
  10.                         doc (vla-get-ActiveDocument (vlax-get-acad-object))
  11.                       )
  12.                     )
  13.                     name
  14.                   )
  15.      )
  16.      (vlax-for obj blkdef
  17.        (setq objs (cons obj objs))
  18.        (if
  19.          (not
  20.            (VL-CATCH-ALL-ERROR-P
  21.              (VL-CATCH-ALL-APPLY 'vla-GetBoundingBox (list obj 'll 'ur))
  22.            )
  23.          )
  24.           (progn
  25.             (setq ll   (vlax-safearray->list ll)
  26.                   ur   (vlax-safearray->list ur)
  27.                   mins (cons ll mins)
  28.                   maxs (cons ur maxs)
  29.             )
  30.           )
  31.        )
  32.      )
  33.      (setq ll (apply 'mapcar (cons 'min mins))
  34.            ur (apply 'mapcar (cons 'max maxs))
  35.      )
  36.      (command "_rectang" "_non" ll "_non" ur)
  37.      (command "_wipeout" "p" (entlast) "y")
  38.      (command "_wipeout" "f" "off")
  39.      (setq wipe (vlax-ename->vla-object (entlast)))
  40.      (setq Newobjs (vlax-invoke
  41.                      doc
  42.                      'CopyObjects
  43.                      objs
  44.                      (vla-get-ModelSpace doc)
  45.                    )
  46.      )
  47.      (foreach a objs (vla-delete a))
  48.      (setq Newobjs (cons wipe Newobjs))
  49.      (vlax-invoke doc 'CopyObjects Newobjs blkdef)
  50.      (foreach a Newobjs (vla-delete a))
  51.      (vla-regen doc :vlax-true)
  52.   )
  53.   (princ)
  54. )
 楼主| 发表于 2013-5-13 10:40:26 | 显示全部楼层
顶顶啊,虽然币不多
发表于 2013-5-14 20:22:38 | 显示全部楼层
这样的程序我也想要。
发表于 2013-5-15 08:30:15 | 显示全部楼层
人家给了编程思路了,给你个画wipeout的代码,其它包围盒、提取块内图元且列表、删除块内图元,添加图元什么的代码论坛有。
  1. ;;  CAB - Jan. 3,2010 to present
  2. (defun MkWipeout(lst / c m p)
  3.   (setq        lst (cons (last lst) lst)
  4.         p   (apply 'mapcar (cons 'min lst))
  5.         m   (apply 'max (mapcar '- (apply 'mapcar (cons 'max lst)) p))
  6.         c   (mapcar '+ p (list (/ m 2.0) (/ m 2.0)))
  7.   )
  8.   (entmakex
  9.     (append (list '(000 . "WIPEOUT")
  10.                   '(100 . "AcDbEntity")
  11.                   '(100 . "AcDbWipeout")
  12.                   (cons 10 (trans p 1 0))
  13.                   (cons 11 (trans (list m 0.0) 1 0))
  14.                   (cons 12 (trans (list 0.0 m) 1 0))
  15.                   '(280 . 1)
  16.                   '(071 . 2)
  17.             )
  18.             (mapcar
  19.               (function
  20.                 (lambda        (x)
  21.                   (cons        14
  22.                         (mapcar        '(lambda (a b c) (/ (- a b) c))
  23.                                 x
  24.                                 c
  25.                                 (list m (- m))
  26.                         )
  27.                   )
  28.                 )
  29.               )
  30.               lst
  31.             )
  32.     )
  33.   )
  34. )
  35. ;;真彩色的含义
  36. ;;(+ (* BLUE 65536) (* GREEN 256) RED)
  37. ;;(+ (* 255 65536) (* 255 256) 255)=16777215
 楼主| 发表于 2013-5-15 08:39:39 | 显示全部楼层
x_s_s_1 发表于 2013-5-15 08:30
人家给了编程思路了,给你个画wipeout的代码,其它包围盒、提取块内图元且列表、删除块内图元,添加图元什么 ...
不会,只会相当简单的LISP,希望有朋友能整理一份
以这个开始深化学习,苦练内功,遇到搞不定的地方发帖咨询,要不混论坛只知道下载有什么意思  发表于 2013-5-15 08:49
 楼主| 发表于 2013-5-15 13:30:46 | 显示全部楼层
发表于 2013-5-19 21:04:54 | 显示全部楼层
能改为框选块就更好
 楼主| 发表于 2013-5-20 08:10:09 | 显示全部楼层
Gu_xl 发表于 2013-5-19 16:02
要是再增加自动转方向就好
不知道影响不影响打印,就是说打印出来也看不到下面的线  发表于 2013-6-9 13:33
 楼主| 发表于 2013-5-20 08:11:54 | 显示全部楼层
希望G版大哥再抽时间能补充补充
GMT+8, 2025-8-23 09:41 , Processed in 0.210899 second(s), 32 queries , Gzip On.
