查看: 4295|回复: 5
[资源] 分享:无需引用dll,通过windows窗体启动CAD并画图
发表于 2013-4-27 12:37:28 | 显示全部楼层 |阅读模式
其实是利用VBA来画图,无需引用其他dll,用VB的高手就简单了,见代码:
private void button9_Click(object sender, EventArgs e)
            MessageBox.Show("请选择要保存的dwg文件!");
            OpenFileDialog pOpenDG = new OpenFileDialog();
            pOpenDG.Filter = "CAD文件(*.dwg)|*.dwg|CAD图形文件(*.dxf)|*.dxf";
            pOpenDG.InitialDirectory = defaultPath;
            pOpenDG.Title = "打开CAD文件";
            if (pOpenDG.ShowDialog() == DialogResult.OK)
                string filePath = pOpenDG.FileName;
                //引用CAD/////////////////////////////////////////////////////////////////////////////////
                System.Globalization.CultureInfo thisThread = System.Threading.Thread.CurrentThread.CurrentCulture;
                thisThread = new System.Globalization.CultureInfo("zh-CHS");
                string appProgID = "AutoCAD.Application";
                Type AcadType = Type.GetTypeFromProgID(appProgID);
                object AcadApp = Activator.CreateInstance(AcadType);
                object[] visargs = new object[1];
                visargs[0] = true;
                AcadApp.GetType().InvokeMember("Visible", BindingFlags.SetProperty, null, AcadApp, visargs, null);
                object AcadDocs = AcadApp.GetType().InvokeMember("Documents", BindingFlags.GetProperty, null, AcadApp, null);
                object[] args = new object[2];
                args[0] = filePath;
                args[1] = false;
                object AcDoc = AcadDocs.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, null, AcadDocs, args, null);
                object Util = new object();
                try
                    //定义CAD数据
                    AcDoc = AcadApp.GetType().InvokeMember("ActiveDocument", BindingFlags.GetProperty, null, AcadApp, null, null);
                    Util = AcDoc.GetType().InvokeMember("Utility", BindingFlags.GetProperty, null, AcDoc, null);
                    object oSpace = AcDoc.GetType().InvokeMember("ModelSpace", BindingFlags.GetProperty, null, AcDoc, null);
                    //画直线
                    double[] startPoint = new double[3];
                    double[] endPoint = new double[3];
                    startPoint[0] = 0; startPoint[1] = 0; startPoint[2] = 0;
                    endPoint[0] = 100; endPoint[1] = 100; endPoint[2] = 0;
                    drawLineInObject(oSpace, startPoint[0], startPoint[1], endPoint[0], endPoint[1], "0");
                    //全屏显示图形
                    AcadApp.GetType().InvokeMember("ZoomExtents", BindingFlags.InvokeMethod, null, AcadApp, null);
                    object[] closeargs = new object[2];
                    closeargs[0] = true;
                    closeargs[1] = filePath;
                    AcDoc.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, null, AcDoc, closeargs);
                    AcadApp.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, null, AcadApp, null);
                    MessageBox.Show("平绘制完成,图形已保存并关闭!");
                catch
                    MessageBox.Show("绘图错误!");
                finally
                    releaseObject(AcDoc);
                    releaseObject(AcadDocs);
                    releaseObject(AcadApp);
                    GC.WaitForPendingFinalizers();
                    GC.GetTotalMemory(true);
                    System.Threading.Thread.CurrentThread.CurrentUICulture = thisThread;
//释放CAD变量
        public static void releaseObject(object obj)
            try
                System.Runtime.InteropServices.Marshal.FinalReleaseComObject(obj);
                obj = null;
            catch
                obj = null;
            finally
                GC.Collect();
//CAD画直线
        public static object drawLineInObject(object oBlock, double startX, double startY, double endX, double endY, string layer)
            double[] begpRef = new double[3];
            double[] endpRef = new double[3];
            begpRef[0] = startX;
            begpRef[1] = startY;
            begpRef[2] = 0.0;
            endpRef[0] = endX;
            endpRef[1] = endY;
            endpRef[2] = 0.0;
            object[] pts = new object[2];
            pts[0] = begpRef;
            pts[1] = endpRef;
            object oLine = oBlock.GetType().InvokeMember("AddLine", BindingFlags.InvokeMethod, null, oBlock, pts);
            oLine.GetType().InvokeMember("Layer", BindingFlags.SetProperty, null, oLine, new object[] { layer });
            oLine.GetType().InvokeMember("Update", BindingFlags.InvokeMethod, null, oLine, null);
            return oLine;
发表于 2013-4-27 12:44:01 | 显示全部楼层
com,vb用这个相当方便
发表于 2013-6-13 10:33:52 | 显示全部楼层
菜鸟路过,不是很明白哦
发表于 2013-6-13 15:52:30 | 显示全部楼层
是通过COM的后期绑定方式,这种是不需要引用,如果采用前期绑定,则需要引用,当然开发上也更快捷。
发表于 2013-7-1 11:13:54 | 显示全部楼层
后期绑定确实不用引用COM,但通过反射调用起来效率大打折扣啊。当然特定情况还是有优势的。
发表于 2013-10-20 15:53:36 | 显示全部楼层
外部开发,不错,习惯这类的了
GMT+8, 2025-5-2 18:42 , Processed in 0.169071 second(s), 24 queries , Gzip On.
