查看: 4402|回复: 6
不改变属性和起点去除多线段冗余点(将假闭合改为闭合)
发表于 2013-4-24 11:35:04 | 显示全部楼层 |阅读模式
(defun Plinexy(e / p a b n ob q et d d1 en et) ;;多线段节点坐标(滤掉了多余点,未处理假闭合)
  (setq a(entget e)ob(vlax-ename->vla-object e)et(cdr(assoc 0 a))n 0 p nil d nil)
  (cond((="LWPOLYLINE"et)
        (repeat (length a)  (setq b (nth n a) n (+ n 1))
          (if (= 10 (car b))(progn
                              (setq q(list (cadr b) (caddr b))d1(vlax-curve-getDistAtPoint ob q))
                              (if p (if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))
                                (setq p (list q))))
       ((="POLYLINE"et)
        (SETQ EN (ENTGET (SETQ E (ENTNEXT E))))
        (WHILE (/= (CDR (ASSOC 0 EN)) "SEQEND")
          (SETQ q (CDR (ASSOC 10 EN))d1(vlax-curve-getDistAtPoint ob q)q(reverse(cdr(reverse q))))
          (if p(if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))
            (setq p (list q)))
          (SETQ EN (ENTGET (SETQ E (ENTNEXT E)))))
        (setq p(reverse p))
  P
(defun RYD(/ m n e e1 f a);;删除冗余点
  (VL-LOAD-COM)
  (setq s(ssget "X"'((0 . "LWPOLYLINE"))))
  (if s(progn
         (setq m(sslength s)n 0)
         (while(< n m)
           (setq e1(ssname s n)n(1+ n)p(Plinexy e1)ob(vlax-ename->vla-object e1)e(entget e1'("*"))F 0)
           (if (or(=(cdr(assoc 70 e))129)(=(cdr(assoc 70 e))1))(setq p(append p(list(car p)))))
           (if (=(vlax-curve-getdistatpoint ob(vlax-curve-getendpoint ob))0)
             (setq p(reverse(cdr(reverse p)))F 1)
           (setq a(list(cons 0 "LWPOLYLINE")(cons 8(cdr(assoc 8 e)))(cons 6(if(assoc 6 e)(cdr(assoc 6 e))""))
                       (cons 62(if(assoc 62 e)(cdr(assoc 62 e))256))(cons 370(if(assoc 370 e)(cdr(assoc 370 e))0))
                       (cons 48(if(assoc 48 e)(cdr(assoc 48 e))1))(cons 100 "AcDbEntity")(cons 100 "AcDbPolyline")
                       (cons 90(-(length P)F))(cons 70 (+ 128 F))(cons 43(if(assoc 43 e)(cdr(assoc 43 e))0))
                       (cons 38(caddr(vlax-curve-getstartpoint ob)))(cons 39(if(assoc 39 e)(cdr(assoc 39 e))0)))
                 a(vl-remove (cons 6 "")a))
           (foreach e P(setq a(append a(list(append(list 10) e)))))
           (entmake(if(assoc -3 e)(append a(list(assoc -3 e)))a))
           (entdel e1)
发表于 2014-4-3 14:55:46 | 显示全部楼层
是删除多段线重复点吗
 楼主| 发表于 2014-4-4 00:15:20 | 显示全部楼层
是的,不过可以不用entdel原线后再ENTMAKE,可以直接ENTMOD的
发表于 2014-4-15 22:13:26 | 显示全部楼层
今天在研究这个关于多余点非重复点,来学习学习。
发表于 2014-7-17 17:23:24 | 显示全部楼层
是真的好复杂啊...
发表于 2016-7-11 09:45:35 | 显示全部楼层
怎么用不了啊,还是我不会用啊
发表于 2022-3-10 10:40:37 | 显示全部楼层
你好楼主命令是啥呀这个程序
GMT+8, 2025-5-24 14:29 , Processed in 0.179595 second(s), 27 queries , Gzip On.
