查看: 4673|回复: 8
二调图封闭区域内的面积统计
发表于 2013-4-21 14:06:57 | 显示全部楼层 |阅读模式
Dim PlineObj As Variant
           Dim point1 As Variant
           Dim point2(0 To 2) As Double
           Dim point3(0 To 2) As Double
           Dim number As Integer
           Dim T As Integer
           Dim char As String '定义要获得的字符串
           Dim dldm As String '定义地类代码
           Dim sts As Double '定义水塘存储的面积变量
           Close #1
           Open "c:\二调地类@815.txt" For Append As #1
           Close #1
           Kill "c:\二调地类@815.txt"
           Close #2
           Open "c:\二调地类面积统计@815.txt" For Append As #2
           Close #2
           Kill "c:\二调地类面积统计@815.txt"
           Set sset = ThisDrawing.SelectionSets.Add(str(Int(Timer))) '用秒数,选择集不会重复
           sset.SelectOnScreen '提示用户选择
           ZoomExtents
           For Each element In sset '在选择集中进行循环
           If element.ObjectName = "AcDbText" Then  '对文字的处理
              If Len(element.TextString) > 6 Then
              T = 0
              char = element.TextString
              dldm = Right(char, 3)
              point1 = element.InsertionPoint '得到块的插入点坐标
              Dim spt As String
              Dim s As Double
              spt = point1(0) & "," & point1(1)
              ThisDrawing.SendCommand Chr(3) & Chr(3) & "-boundary " & spt & " " & " "
              ThisDrawing.SendCommand "draworder last  f "
              ThisDrawing.SendCommand "_.area o last "
              If dldm = "114" Then '水塘sts
              sts = ThisDrawing.GetVariable("AREA") + sts
              T = 1
              End If
              If dldm = "013" Then '旱地hds
              hds = ThisDrawing.GetVariable("AREA") + hds
              T = 1
              End If
              If dldm = "011" Then '水稻sds
              sds = ThisDrawing.GetVariable("AREA") + sds
              T = 1
              End If
              If dldm = "012" Then '水浇地sjds
              sjds = ThisDrawing.GetVariable("AREA") + sjds
              T = 1
              End If
              If dldm = "021" Then '果园gys
              gys = ThisDrawing.GetVariable("AREA") + gys
              T = 1
              End If
              If dldm = "031" Then '有林地ylds
              ylds = ThisDrawing.GetVariable("AREA") + ylds
              T = 1
              End If
              If dldm = "033" Then '其它林地qtlds
              qtlds = ThisDrawing.GetVariable("AREA") + qtlds
              T = 1
              End If
              If dldm = "043" Then '其它草地qtcds
              qtcds = ThisDrawing.GetVariable("AREA") + qtcds
              T = 1
              End If
              If dldm = "102" Then '公路用地glyds
              glyds = ThisDrawing.GetVariable("AREA") + glyds
              T = 1
              End If
              If dldm = "203" Then '村庄czs
              czs = ThisDrawing.GetVariable("AREA") + czs
              T = 1
              End If
              If dldm = "202" Then '建制镇jzzs
              jzzs = ThisDrawing.GetVariable("AREA") + jzzs
              T = 1
              End If
              If dldm = "204" Then '采矿用地ckyds
              ckyds = ThisDrawing.GetVariable("AREA") + ckyds
              T = 1
              End If
              If dldm = "117" Then '沟渠gqs
              gqs = ThisDrawing.GetVariable("AREA") + gqs
              T = 1
              End If
              If dldm = "113" Then '湖泊水面hpsms
              hpsms = ThisDrawing.GetVariable("AREA") + hpsms
              T = 1
              End If
              If dldm = "205" Then '风景名胜fjmss
              fjmss = ThisDrawing.GetVariable("AREA") + fjmss
              T = 1
              End If
              If dldm = "122" Then '设施农用地sslyds
              sslyds = ThisDrawing.GetVariable("AREA") + sslyds
              T = 1
              End If
              If dldm = "118" Then '水工建筑sgjzs
              sgjzs = ThisDrawing.GetVariable("AREA") + sgjzs
              T = 1
              End If
              If dldm = "113" Then '水库水面sksms
              sksms = ThisDrawing.GetVariable("AREA") + sksms
              T = 1
              End If
              If dldm = "022" Then '茶园cys
              cys = ThisDrawing.GetVariable("AREA") + cys
              T = 1
              End If
              If T = 0 Then
              Print #1, dldm
              Close #1
              End If
           End If
           End If
           'ThisDrawing.GetVariable.Delete
           Next
              Print #2, "茶园"; cys; "水库水面:"; sksms; "水工建筑:"; sgjzs; "设施农用地:"; sslyds; "风景名胜:"; fjmss; "湖泊水面:"; hpsms; "沟渠:"; gqs; "采矿用地:"; ckyds; "建制镇:"; jzzs; "村庄:"; czs; "公路用地:"; glyds; "其它草地:"; qtcds; "其它林地:"; qtlds; "有林地:"; ylds; "果园:"; gys; "水浇地:"; sjds; "水稻:"; sds; "旱地:"; hds; "水塘:"; sts
              Close #2
 楼主| 发表于 2013-4-21 14:17:51 | 显示全部楼层
附例图,请高手们帮我看看。理论上好像没问题,但是实际操作时,整幅图选择时就会很慢,最后导致内存不足。是不是cad自带的查找封闭区域有bug呢、?请高手指点。zxj_76看到吗?
发表于 2013-4-21 14:27:09 | 显示全部楼层
现在发现VB的看不懂了
 楼主| 发表于 2013-4-29 20:17:24 | 显示全部楼层
呵呵,好像不太热呀,自己先顶一下
发表于 2013-5-1 16:29:05 | 显示全部楼层
高手开发一个关于这的LSP代码!
发表于 2013-5-1 18:36:28 | 显示全部楼层
程序中问题多:
    1、文件没有打开之前,为什么用close;而文件打开之后没有任何操作又关闭;
    2、选择集只用建一个即可,首先判断是否存在,如存在则删除后新建,否则新建即可;
    3、boundary命令不一定能成功建立边界;
    4、有些标注文字(如“1335||114”)不在正确的位置上,将导致面积统计错误;
    5、那些if ... then ... end if改为如下形式较好
       Dim amj As Double
           amj = ThisDrawing.GetVariable("AREA")
              Select Case dldm
                   Case "114"  '水塘sts
                       sts = sts + amj: T = 1
                   Case "013"  '旱地hds
                       hds = hds + amj: T = 1
                   Case "011"  '水稻sds
                       sds = sds + amj: T = 1
                   Case "012"  '水浇地sjds
                       sjds = sjds + amj: T = 1
                   Case "021"  '果园gys
                       gys = gys + amj: T = 1
                   Case "031"  '有林地ylds
                        ylds = ylds + amj: T = 1
                   Case "033"  '其它林地qtlds
                        dtlds = qtlds + amj: T = 1
                   Case "043"   '其它草地qtcds
                        qtcds = qtcds + amj: T = 1
           End Select
   6、没有统计的面积与入文件;
 楼主| 发表于 2013-5-1 20:33:13 | 显示全部楼层
捉摸了几天,影响boundary出错的主要原因是屏幕显视,boundary命令执行时封闭区域必须要完整显视在屏幕内,否则会出错。但是屏幕显视区域也不能太小,如果太小也容易会出错,另外还导致死机(屏幕区域小了就导致每次分析的数据量增大)。这次把程序调整了一下。主要思路是分类和指定屏幕选择的大小,比如114水塘,这些面积都较小,所以可以把屏幕显视调小,遇到大的河流和村庄等大面积的则要适当增加。
但是统计数据还是加入一些人工干预,只能减少工作量,还没有达到一个命令就能完事的那种程度。
哎,总而言之,理论上按程序写的是能通过,但是实际上boundary有很多漏洞。不知道是开发者故意留的还是怎么的。
如果想能得到更满意的结果,估计要彻底改变思路。
楼上的谢谢了,你给我指出了很多问题,一看就是高手。以后多多指教呀。
 楼主| 发表于 2013-5-1 20:36:03 | 显示全部楼层
Dim oAJlayer As AcadLayer
           Dim layercollection As AcadLayers
           Dim dlmj As Double '定义水塘存储的面积变量
           Dim getchar As String
           Dim a As Integer
           dlmj = 0: dlmj1 = 0: a = 0
           Close #1
           Close #1
           Close #2
           Close #2
           getchar = ThisDrawing.Utility.GetString(3, "请输入要统计的地类代号:")
           a = ThisDrawing.Utility.GetInteger("请输入视窗大小:")
            Dim ft1(0) As Integer
            Dim fd1(0) As Variant
            ft1(0) = 8
            fd1(0) = "ZDH1"
            sset.Select acSelectionSetAll, , , ft1, fd1
            Set layercollection = ThisDrawing.Layers
            Set oAJlayer = layercollection.Add(getchar & "地类统计")
            ThisDrawing.ActiveLayer = oAJlayer '设置当前图层
            ThisDrawing.ActiveLayer.color = acGreen '设置当前图层的颜色
                  dldm = Right(element.TextString, 3)
                       If dldm = getchar Then
                          Dim spt As String
                          Dim spt1(0 To 2) As Double
                          Dim spt2(0 To 2) As Double
                          Dim s As Double
                          spt1(0) = point1(0) - a
                          spt1(1) = point1(1) + a
                          spt1(2) = 0
                          spt2(0) = point1(0) + a
                          spt2(1) = point1(1) - a
                          spt2(2) = 0
                          ZoomWindow spt1, spt2
                         'ZoomExtents
                          dlmj = ThisDrawing.GetVariable("AREA") + dlmj
                          element.color = acRed
                       End If
               End If
           Next
               Print #2, getchar; ":"; dlmj; "合:"; dlmj * 0.0015; "亩"
               Close #2
 楼主| 发表于 2013-5-1 20:39:40 | 显示全部楼层
例图,忘了说了,暂时这个程序还没有考虑到文字不在方框内的那种情况。是手工挪的。这个程序如果能如想的那样搞好的话,再搞下一步吧,这个例图已经完全没有问题了。114输入40可通过。
GMT+8, 2025-5-1 07:34 , Processed in 0.187633 second(s), 28 queries , Gzip On.
