查看: 4067|回复: 15
文件格式转换
发表于 2013-4-19 20:29:45 | 显示全部楼层 |阅读模式
请大伙测试下这个文件转换格式小工具;适合.txt .dat .xyz .csv
发表于 2013-4-21 13:20:39 | 显示全部楼层
我试试
,,,看看
发表于 2013-4-21 13:28:20 | 显示全部楼层
转换前  dmxyh   dat    转换后 dxy  出点小问题 可能是我不会用
源文件
1-1,904,41611.220,54911.660,219.880
1-2,230,41729.280,54926.100,227.630
1-3,230,41730.220,54934.820,228.910
1-4,230,41736.600,54936.820,231.890
1-5,230,41743.370,54936.710,231.860
1-6,230,41750.420,54936.740,231.970
1-7,230,41757.070,54936.640,232.360
1-8,230,41763.470,54936.530,232.120
1-9,230,41767.020,54936.490,232.410
1-10,230,41782.420,54936.300,234.290
1-11,230,41764.350,54927.530,229.270
转换后
1北向X东向Y90441611.22054911.660219.880
2北向X东向Y23041729.28054926.100227.630
3北向X东向Y23041730.22054934.820228.910
4北向X东向Y23041736.60054936.820231.890
5北向X东向Y23041743.37054936.710231.860
6北向X东向Y23041750.42054936.740231.970
7北向X东向Y23041757.07054936.640232.360
8北向X东向Y23041763.47054936.530232.120
9北向X东向Y23041767.02054936.490232.410
10北向X东向Y23041782.42054936.300234.290
11北向X东向Y23041764.35054927.530229.270
 楼主| 发表于 2013-4-21 14:23:21 | 显示全部楼层
源文件
1-1,904,41611.220,54911.660,21 ...
需要转换后的是什么格式?
发表于 2013-4-21 14:36:19 | 显示全部楼层
其实这个就是我用的格式,cass
我刚才测试您写的程序  想转换成 1-1,41611.220,54911.660
gzxl + 1 多谢参与
 楼主| 发表于 2013-4-21 14:56:21 | 显示全部楼层
其实这个就是我用的格式,cass
正常啊
发表于 2013-4-21 15:00:46 | 显示全部楼层
gzxl 发表于 2013-4-21 14:56
正常啊
估计是我点错了,我当时没点到 逗号。
确认了下,当时没点逗号,我以为自动识别都好了。。。。。
发表于 2013-4-22 10:58:10 | 显示全部楼层
顶顶顶,顶一下
发表于 2013-4-24 12:46:56 | 显示全部楼层
真的很棒的程序!
赞一个!
发表于 2013-4-25 23:22:18 | 显示全部楼层
我也测试了,出了点小问题,请老大指正
就是XY列,不能安装设置的顺序转换,试了几次,顺序变不过来。
转换前格式就是CASS格式,参照老大的操作图片,确认格式定义不错
转换前:点名,,y,x,h
欲转换为:点名,X,Y,H
转换前:1,,447147.495,3759417.994,36.61
2,,447121.089,3759406.19,37.238
3,,447113.647,3759423.164,37.265
4,,447106.645,3759439.186,37.249
5,,447105.255,3759438.554,37.253
6,,447094.94,3759465.899,37.19
7,,447084.911,3759488.797,37.125
8,,447087.261,3759490.077,36.354
9,,447079.882,3759500.34,37.125
10,,447074.13,3759499.339,36.47
转换后:
1,447147.495,3759417.994,36.61
2,447121.089,3759406.19,37.238
3,447113.647,3759423.164,37.265
4,447106.645,3759439.186,37.249
5,447105.255,3759438.554,37.253
6,447094.94,3759465.899,37.19
7,447084.911,3759488.797,37.125
8,447087.261,3759490.077,36.354
9,447079.882,3759500.34,37.125
10,447074.13,3759499.339,36.47
gzxl + 1 一楼已更新
GMT+8, 2025-5-1 05:32 , Processed in 0.173935 second(s), 33 queries , Gzip On.
