查看: 3829|回复: 14
[基础] 现有复制标高能增加标高数值,如何实现拉伸或者移动标高同样可以改变标高数值(已....
发表于 2013-4-19 10:23:05 | 显示全部楼层 |阅读模式
;;复制标高,标高数字自动修改
(defun c:jbg ()
  ;(PXT_ER)
  (defun DXF (n da) (cdr (assoc n da)))
  (setq        xtblm '("osmode" "clayer" "cecolor" "orthomode" "plinewid")
        xtblz (mapcar 'getvar xtblm)
  (setvar "osmode" 1) ;_捕捉端点
  (princ "\n请选择要复制\"图层为_B标高\"的标高(退出):")
;;;  (setq        ss (ssget ":L"
;;;                  (list (cons 8 "B标高"))
  (setq ss (ssget))
  (if ss
      (command "undo" "be")
      (if (null bl-cb)
        (setq bl-cb 1.0)
      (prompt (strcat "\n当前缩放比例:【" (rtos bl-cb 2 1) "】"))
      (initget "Bili")
      (setq p1 (getpoint "\nBili改变比例/ 基点(退出):"))
      (while (= p1 "Bili")
        (setq
          bl-cb2
           (getreal (strcat "\n请输入比例:<" (rtos bl-cb 2 1) ">")
        (if bl-cb2
          (setq bl-cb bl-cb2)
          (setq bl-cb bl-cb)
        (initget "Bili")
      (setvar "osmode" 673) ;_捕捉端点、交叉点、最近点 垂足
      (while (setq p2 (getpoint p1 "\n拷贝至 (退出): "))
        ;; 返回复制后,新生成的物体ss_new
        (setq en_Last (entlast)
              ss_new  (ssadd)
        (command "copy" ss "" p1 p2)
        (setq en_next (entnext en_Last))
        (while en_next
          (ssadd en_next ss_new)
          (setq en_next (entnext en_next))
        (setq i 0)
        (repeat        (sslength ss_new)
          (setq        en   (ssname ss_new i)
                da   (entget en)
                enty (DXF 0 da)
          (cond
            ;;处理:普通标高text 天正标高
            ((member enty (list "TEXT" "TCH_ELEVATION"))
             (setq txt (DXF 1 da))
             (if (or (= txt "%%p0.000")
                     (= txt "0") ;_Tch标高为 (1 . "0")
                     (and (/= (atof txt) 0)
                          (wcmatch txt "*.*")
                 ;;--计算高差----
                 (setq d   (- (cadr p2) (cadr p1))
                       d   (* d 0.001 bl-cb)
                       num (+ (atof txt) d)
                 (setq txt-n (rtos num 2 3))
                 (if (= txt-n "0.000")
                   (setq txt-n "%%p0.000")
                 (setq da (subst (cons 1 txt-n) (assoc 1 da) da))
                 (entmod da)
            ;;处理:属性标高
            ((member enty (list "INSERT"))
             (setq da  (entget (entnext en))
                   txt (DXF 1 da)
             ;;--计算高差----
                   d   (* d 0.001 bl-cb)
             ;; 替换属性文字
             (setq da (entget (entnext en)))
             (entmod da)
             (entupd en)
             (entupd (entnext en))
          ) ;_ cond
          (setq i (1+ i))
        ) ;_end repeat
      ) ;_end while
      (command "undo" "e")
  ) ;_ if ss
  (mapcar 'setvar xtblm xtblz)
以上是网络上寻找到的复制标高同时能增加标高数值的源码(感谢原作者),现有复制标高能增加标高数值,如何实现拉伸或者移动标高同样可以改变标高数值?请赐教
 楼主| 发表于 2013-4-19 12:08:11 | 显示全部楼层
自己顶一下
发表于 2013-4-19 19:46:54 | 显示全部楼层
盼望高手出现啊!同求!
 楼主| 发表于 2013-4-19 20:24:22 | 显示全部楼层
vlisp2012 发表于 2013-4-19 19:46
盼望高手出现啊!同求!
自己改了一下,没有用啊
 楼主| 发表于 2013-4-21 13:06:09 | 显示全部楼层
继续顶,呵呵
发表于 2013-4-21 14:11:08 | 显示全部楼层
如果你用的CAD版本较高的话,虽然我不什么高手,但可以参考一下我之前发过的字段功能
http://bbs.mjtd.com/thread-100352-1-1.html
它会按实际情况自动更新
 楼主| 发表于 2013-4-21 22:36:01 | 显示全部楼层
http://bbs.mjtd.com ...
多谢指点,去看看先
发表于 2013-4-27 10:19:24 | 显示全部楼层
这个程序好像是我以前发的。
如果移动就改变标高的话,更简单了。
修改以下的ss_new选择集,改为你移动的选择集。
              ss_new  (ssadd)
        (while en_next
        (setq i 0)
发表于 2013-4-27 12:52:23 | 显示全部楼层
估计你需要的是反应器。这个有点深,玩不好都会崩溃的。
 楼主| 发表于 2013-4-27 15:43:31 | 显示全部楼层
谢谢,一切安好?
GMT+8, 2025-7-16 09:25 , Processed in 0.192032 second(s), 32 queries , Gzip On.
