- 积分
- 5789
- 明经币
- 个
- 注册时间
- 2010-1-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2013-4-2 12:49:46
显示全部楼层
 - using Autodesk.AutoCAD.ApplicationServices;
- using Autodesk.AutoCAD.DatabaseServices;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.Geometry;
- using Autodesk.AutoCAD.Runtime;
- namespace TableCreation
- public class Commands
- [CommandMethod("CRT")]
- static public void CreateTable()
- Document doc =
- Application.DocumentManager.MdiActiveDocument;
- Database db = doc.Database;
- Editor ed = doc.Editor;
- PromptPointResult pr =
- ed.GetPoint("\nEnter table insertion point: ");
- if (pr.Status == PromptStatus.OK)
- Table tb = new Table();
- tb.TableStyle = db.Tablestyle;
- tb.NumRows = 5;
- tb.NumColumns = 3;
- tb.SetRowHeight(3);
- tb.SetColumnWidth(15);
- tb.Position = pr.Value;
- // Create a 2-dimensional array
- // of our table contents
- string[,] str = new string[5, 3];
- str[0, 0] = "Part No.";
- str[0, 1] = "Name ";
- str[0, 2] = "Material ";
- str[1, 0] = "1876-1";
- str[1, 1] = "Flange";
- str[1, 2] = "Perspex";
- str[2, 0] = "0985-4";
- str[2, 1] = "Bolt";
- str[2, 2] = "Steel";
- str[3, 0] = "3476-K";
- str[3, 1] = "Tile";
- str[3, 2] = "Ceramic";
- str[4, 0] = "8734-3";
- str[4, 1] = "Kean";
- str[4, 2] = "Mostly water";
- // Use a nested loop to add and format each cell
- for (int i = 0; i < 5; i++)
- for (int j = 0; j < 3; j++)
- tb.SetTextHeight(i, j, 1);
- tb.SetTextString(i, j, str[i, j]);
- tb.SetAlignment(i, j, CellAlignment.MiddleCenter);
- tb.GenerateLayout();
- Transaction tr =
- doc.TransactionManager.StartTransaction();
- using (tr)
- BlockTable bt =
- (BlockTable)tr.GetObject(
- doc.Database.BlockTableId,
- OpenMode.ForRead
- BlockTableRecord btr =
- (BlockTableRecord)tr.GetObject(
- bt[BlockTableRecord.ModelSpace],
- OpenMode.ForWrite
- btr.AppendEntity(tb);
- tr.AddNewlyCreatedDBObject(tb, true);
- tr.Commit();
稍加修改就可以了(遍历一下DatagrideView)
这些本版内都有的(我只是复制粘贴而已) |
