查看: 55878|回复: 215
一键恢复系统变量为初始值(源码)
发表于 2013-1-23 13:38:19 | 显示全部楼层 |阅读模式
  想以2K版本为基础,搞一个万能的"一键恢复系统变量为初始值"
在安装目录下\\Express\\defaults.scr,只是对本版本有效。
我找到了05版,10版的defaults.scr,请各位帮助上传一个其它版本的defaults.scr和(getvar "acadver"),完成后公布源码。
在此先表示感谢!
;;比较两个版本scr文件,找出不同的变量
;;******************************自贡运机集团 自贡黄明儒 2013年1月24日
(defun C:CompareScr
       (/ BOOL FILE FILE1 FILE2 FN1 FN2 INITDIR TEMP_FILE X1 X11 X2 X22)
  (setq Initdir (getvar "dwgprefix"))
  (if
    (and (setq
    file1 (getfiled "选择 较高 版本的scr文件" Initdir "scr" 0)
  (setq Initdir (strcat (vl-filename-directory file1) "\\"))
  (setq
    file2 (getfiled "选择 较低 版本的scr文件" Initdir "scr" 0)
       ;;(setq Temp_File (vl-filename-mktemp nil nil ".txt"))
       (setq Temp_File "Temp_File.txt")
       (setq File (open Temp_File "w"))
       (setq fn1 (open file1 "r"))
       (while (setq x11 (read-line fn1))
  (setq x1 (read x11))
  (setq fn2 (open file2 "r"))
  (setq bool T)
  (while (and (setq x22 (read-line fn2)) bool)
    (setq x2 (read x22))
    (if (and (equal (cadr x1) (cadr x2))
      (equal (caddr x1) (caddr x2))
      (setq bool nil)
  (if bool (write-line x11 FILE))
  (close fn2)
       (close fn1)
       (close FILE)
       (startapp "notepad" Temp_File)
;;将defaults13.scr文件转换成表
  1. (defun C:Scr2list (/ FILE1 FN1 INITDIR VARLIST X1 X2)
  2.   (setq Initdir (getvar "dwgprefix"))
  3.   (setq file1 (getfiled "选择defaults13.scr文件" Initdir "scr" 0))
  4.   ;;(setq Temp_File "Temp_File.txt")
  5.   ;;(setq File (open Temp_File "w"))
  6.   (setq fn1 (open file1 "r"))
  7.   (while (setq x1 (read-line fn1))
  8.     (setq x1 (read x1))
  9.     (setq VarList (cons (cadr x1) VarList))
  10.     (setq valueList (cons (caddr x1) valueList))
  11.   )
  12.   (close fn1)
  13. )
;;一键恢复系统变量为初始值(基本上搞定)(源码)
;;下面的程序根据bagu提供的2014版的defaults.scr为基础写的
(setq VarList '("ZOOMWHEEL"        "ZOOMFACTOR"       "XREFTYPE"         "XREFNOTIFY"       "XREFCTL"
"XLOADCTL"         "XFADECTL"         "XEDIT"            "XCLIPFRAME"
                "WORLDVIEW"        "WMFFOREGND"       "WMFBKGND"         "WINDOWAREACOLOR"  "WHIPTHREAD"
"WHIPARC"          "VTFPS"            "VTENABLE"         "VTDURATION"
                "VSSILHWIDTH"      "VSSILHEDGES"      "VSSHADOWS"        "VSOBSCUREDLTYPE"  "VSOBSCUREDEDGES"
"VSOBSCUREDCOLOR"  "VSMONOCOLOR"      "VSMATERIALMODE"   "VSLIGHTINGQUALITY"
                "VSISOONTOP"       "VSINTERSECTIONLTYPE"                 "VSINTERSECTIONEDGES"
"VSINTERSECTIONCOLOR"                 "VSHIDEPRECISION"  "VSHALOGAP"
                "VSFACESTYLE"      "VSFACEOPACITY"    "VSFACEHIGHLIGHT"  "VSFACECOLORMODE"  "VSEDGESMOOTH"
"VSEDGES"          "VSEDGEOVERHANG"   "VSEDGEJITTER"     "VSEDGECOLOR"
                "VSBACKGROUNDS"    "VPLAYEROVERRIDESMODE"                "VISRETAIN"        "USERS5"
"USERS4"           "USERS3"           "USERS2"           "USERS1"
                "USERR5"           "USERR4"           "USERR3"           "USERR2"           "USERR1"
"USERI5"           "USERI4"           "USERI3"           "USERI2"
                "USERI1"           "UPDATETHUMBNAIL"  "UNITMODE"         "UCSVP"            "UCSVIEW"
"UCSORTHO"         "UCSICON"          "UCSFOLLOW"        "UCSDETECT"
                "UCSBASE"          "UCSAXISANG"       "TSTACKSIZE"       "TSTACKALIGN"      "TSPACETYPE"
"TSPACEFAC"        "TRUSTEDPATHS"     "TRUSTEDDOMAINS"   "TRIMMODE"
                "TREEMAX"          "TREEDEPTH"        "TRAYTIMEOUT"      "TRAYNOTIFY"       "TRAYICONS"
"TRACKPATH"        "TRACEWID"         "TOOLTIPS"         "TOOLTIPMERGE"
                "TIMEZONE"         "TILEMODE"         "THICKNESS"        "TEXTSTYLE"        "TEXTSIZE"
"TEXTQLTY"         "TEXTOUTPUTFILEFORMAT"                "TEXTFILL"
                "TEXTEVAL"         "TEMPOVERRIDES"    "TBCUSTOMIZE"      "TABMODE"          "TABLETOOLBAR"
"TABLEINDICATOR"   "SURFV"            "SURFU"            "SURFTYPE"
                "SURFTAB2"         "SURFTAB1"         "SUNSTATUS"        "SUBOBJSELECTIONMODE"
"STEPSPERSEC"      "STEPSIZE"         "STATUSBAR"        "STARTUP"
                "STANDARDSVIOLATION"                  "SSMSHEETSTATUS"   "SSMPOLLTIME"      "SSMAUTOOPEN"
"SSLOCATE"         "SPLINETYPE"       "SPLINESEGS"       "SPLFRAME"
                "SORTENTS"         "SOLIDHIST"        "SOLIDCHECK"       "SNAPUNIT"         "SNAPTYPE"
"SNAPSTYL"         "SNAPMODE"         "SNAPISOPAIR"      "SNAPBASE"
                "SNAPANG"          "SMOOTHMESHMAXLEV" "SMOOTHMESHMAXFACE"                   "SMOOTHMESHGRID"
"SMOOTHMESHCONVERT"                   "SKPOLY"           "SKETCHINC"
                "SIGWARN"          "SHPNAME"          "SHOWLAYERUSAGE"   "SHOWHIST"         "SHORTCUTMENU"
"SHADOWPLANELOCATION"                 "SHADEDIF"         "SHADEDGE"
                "SETBYLAYERMODE"   "SELECTIONPREVIEW" "SELECTIONAREAOPACITY"                "SELECTIONAREA"
"SELECTIONANNODISPLAY"                "SECURELOAD"       "SAVETIME"
                "SAVEFIDELITY"     "RTDISPLAY"        "REPORTERROR"      "RENDERUSERLIGHTS" "REMEMBERFOLDERS"
"RE-INIT"          "REGENMODE"        "RECOVERYMODE"     "RASTERTHRESHOLD"
                "RASTERPREVIEW"    "RASTERPERCENT"    "RASTERDPI"        "QTEXTMODE"        "PUCSBASE"
"PUBLISHHATCH"     "PUBLISHCOLLATE"   "PUBLISHALLSHEETS" "PSVPSCALE"
                "PSTYLEPOLICY"     "PSOLWIDTH"        "PSOLHEIGHT"       "PSLTSCALE"        "PROXYSHOW"
"PROXYNOTICE"      "PROXYGRAPHICS"    "PROJMODE"         "PROJECTNAME"
                "PREVIEWFILTER"    "PREVIEWEFFECT"    "POLYSIDES"        "POLARMODE"        "POLARDIST"
"POLARANG"         "POLARADDANG"      "PLQUIET"          "PLOTROTMODE"
                "PLOTOFFSET"       "PLINEWID"         "PLINETYPE"        "PLINEGEN"         "PLINECONVERTMODE"
"PICKSTYLE"        "PICKFIRST"        "PICKDRAG"         "PICKBOX"
                "PICKAUTO"         "PICKADD"          "PERSPECTIVECLIP"  "PERSPECTIVE"      "PELLIPSE"
"PEDITACCEPT"      "PDSIZE"           "PDMODE"           "PAPERUPDATE"
                "PALETTEOPAQUE"    "OSOPTIONS"        "OSNAPZ"           "OSNAPNODELEGACY"  "OSNAPCOORD"
"OSMODE"           "ORTHOMODE"        "OLESTARTUP"       "OLEQUALITY"
                "OLEHIDE"          "OLEFRAME"         "OFFSETGAPTYPE"    "OFFSETDIST"       "OBSCUREDLTYPE"
"OBSCUREDCOLOR"    "NOMUTT"           "NAVSWHEELSIZEMINI"
                "NAVSWHEELSIZEBIG" "NAVSWHEELOPACITYMINI"                "NAVSWHEELOPACITYBIG"
"NAVSWHEELMODE"    "NAVVCUBESIZE"     "NAVVCUBEOPACITY"  "NAVVCUBELOCATION"
                "NAVVCUBEDISPLAY"  "MTJIGSTRING"      "MTEXTTOOLBAR"     "MTEXTFIXED"       "MTEXTED"
"MSLTSCALE"        "MSOLESCALE"       "MODEMACRO"        "MLEADERSCALE"
                "MIRRTEXT"         "MESHTYPE"         "MENUECHO"         "MENUCTL"          "MEASUREMENT"
"MEASUREINIT"      "MBUTTONPAN"       "MAXSORT"          "MAXACTVP"
                "LWUNITS"          "LWDISPLAY"        "LWDEFAULT"        "LUPREC"           "LUNITS"
"LTSCALE"          "LONGITUDE"        "LOGFILEMODE"      "LOGEXPPHYSICALSCALE"
                "LOGEXPMIDTONES"   "LOGEXPDAYLIGHT"   "LOGEXPCONTRAST"   "LOGEXPBRIGHTNESS" "LOFTPARAM"
"LOFTNORMALS"      "LOFTMAG2"         "LOFTMAG1"         "LOFTANG2"
                "LOFTANG1"         "LOCKUI"           "LINEARCONTRAST"   "LINEARBRIGHTNESS" "LIMMIN"
"LIMMAX"           "LIMCHECK"         "LIGHTSINBLOCKS"   "LIGHTINGUNITS"
                "LIGHTGLYPHDISPLAY"                   "LENSLENGTH"       "LEGACYCTRLPICK"   "LAYOUTREGENCTL"
"LAYLOCKFADECTL"   "LAYERNOTIFY"      "LAYERFILTERALERT" "LAYEREVAL"
                "LASTPOINT"        "ISOLINES"         "ISAVEPERCENT"     "ISAVEBAK"
"INTERSECTIONDISPLAY"                 "INTERSECTIONCOLOR"                   "INTERFEREVPVS"
                "INTERFEREOBJVS"   "INTERFERECOLOR"   "INTELLIGENTUPDATE"                   "INSUNITSDEFTARGET"
                 "INSUNITSDEFSOURCE"                   "INSUNITS"
                "INSNAME"          "INSBASE"          "INPUTHISTORYMODE" "INETLOCATION"     "INDEXCTL"
"IMPLIEDFACE"      "IMAGEHLT"         "HYPERLINKBASE"    "HPSPACE"
                "HPSEPARATE"       "HPSCALE"          "HPORIGINMODE"     "HPORIGIN"         "HPOBJWARNING"
"HPNAME"           "HPMAXLINES"       "HPINHERIT"        "HPGAPTOL"
                "HPDRAWORDER"      "HPDOUBLE"         "HPBOUND"          "HPASSOC"          "HPANG"
"HIGHLIGHT"        "HIDETEXT"         "HIDEPRECISION"    "HALOGAP"
                "GTLOCATION"       "GTDEFAULT"        "GTAUTO"           "GRIPTIPS"         "GRIPSUBOBJMODE"
"GRIPSIZE"         "GRIPS"            "GRIPOBJLIMIT"     "GRIPHOVER"
                "GRIPHOT"          "GRIPDYNCOLOR"     "GRIPCOLOR"        "GRIPBLOCK"        "GRIDUNIT"
"GRIDMODE"         "GRIDMAJOR"        "GRIDDISPLAY"      "FULLPLOTPATH"
                "FONTMAP"          "FONTALT"          "FILLMODE"         "FILLETRAD"        "FILEDIA"
"FIELDEVAL"        "FIELDDISPLAY"     "FACETRES"         "FACETRATIO"
                "FACETERSMOOTHLEV" "FACETERPRIMITIVEMODE"                "FACETERMESHTYPE"  "FACETERMINVGRID"
"FACETERMINUGRID"  "FACETERMAXGRID"   "FACETERMAXEDGELENGTH"
                "FACETERGRIDRATIO" "FACETERDEVSURFACE"                   "FACETERDEVNORMAL" "EXTNAMES"
"EXPLMODE"         "EXPERT"           "ELEVATION"        "EDGEMODE"
                "DYNTOOLTIPS"      "DYNPROMPT"        "DYNPIVIS"         "DYNPIFORMAT"      "DYNPICOORDS"
"DYNMODE"          "DYNDIVIS"         "DYNDIGRIP"        "DXEVAL"
                "DWGCHECK"         "DWFOSNAP"         "DWFFRAME"         "DTEXTED"          "DRAWORDERCTL"
"DRAGVS"           "DRAGP2"           "DRAGP1"           "DRAGMODE"
                "DONUTOD"          "DONUTID"          "DIVMESHTORUSSECTION"                 "DIVMESHTORUSPATH"
"DIVMESHWEDGEBASE" "DIVMESHWEDGESLOPE"                   "DIVMESHWEDGEHEIGHT"
                "DIVMESHWEDGEWIDTH"                   "DIVMESHWEDGELENGTH"
"DIVMESHSPHEREHEIGHT"                 "DIVMESHSPHEREAXIS"                   "DIVMESHPYRHEIGHT"
                "DIVMESHPYRBASE"   "DIVMESHPYRLENGTH" "DIVMESHCYLHEIGHT" "DIVMESHCYLBASE"   "DIVMESHCYLAXIS"
"DIVMESHCONEHEIGHT"                   "DIVMESHCONEBASE"  "DIVMESHCONEAXIS"
                "DIVMESHBOXHEIGHT" "DIVMESHBOXWIDTH"  "DIVMESHBOXLENGTH" "DISPSILH"         "DIMZIN"
"DIMUPT"           "DIMTZIN"          "DIMTXT"           "DIMTXSTY"
                "DIMTVP"           "DIMTSZ"           "DIMTP"            "DIMTOLJ"          "DIMTOL"
"DIMTOH"           "DIMTOFL"          "DIMTMOVE"         "DIMTM"
                "DIMTIX"           "DIMTIH"           "DIMTFILLCLR"      "DIMTFILL"         "DIMTFAC"
"DIMTDEC"          "DIMTAD"           "DIMSOXD"          "DIMSE2"
                "DIMSE1"           "DIMSD2"           "DIMSD1"           "DIMSCALE"         "DIMSAH"
"DIMRND"           "DIMPOST"          "DIMLWE"           "DIMLWD"
                "DIMLUNIT"         "DIMLTYPE"         "DIMLTEX2"         "DIMLTEX1"         "DIMLIM"
"DIMLFAC"          "DIMLDRBLK"        "DIMJUST"          "DIMJOGANG"
                "DIMGAP"           "DIMFXLON"         "DIMFXL"           "DIMFRAC"          "DIMFIT"
"DIMEXO"           "DIMEXE"           "DIMDSEP"          "DIMDLI"
                "DIMDLE"           "DIMDEC"           "DIMCONTINUEMODE"  "DIMCLRT"          "DIMCLRE"
"DIMCLRD"          "DIMCEN"           "DIMBLK2"          "DIMBLK1"
                "DIMBLK"           "DIMAZIN"          "DIMAUNIT"         "DIMATFIT"         "DIMASZ"
"DIMASSOC"         "DIMARCSYM"        "DIMAPOST"         "DIMALTZ"
                "DIMALTU"          "DIMALTTZ"         "DIMALTTD"         "DIMALTRND"        "DIMALTF"
"DIMALTD"          "DIMALT"           "DIMADEC"          "DGNOSNAP"
                "DGNFRAME"         "DEMANDLOAD"       "DELOBJ"           "DEFAULTLIGHTINGTYPE"
"DEFAULTLIGHTING"  "DEFAULTGIZMO"     "DBLCLKEDIT"       "DATALINKNOTIFY"
                "CVPORT"           "CURSORSIZE"       "CTABLESTYLE"      "CSHADOW"          "CROSSINGAREACOLOR"
                 "COPYMODE"         "COORDS"           "CONSTRAINTINFER"
                "COMPASS"          "CMLSTYLE"         "CMLSCALE"         "CMLJUST"          "CMLEADERSTYLE"
"CMDINPUTHISTORYMAX"                  "CMDECHO"          "CMDDIA"
                "CMATERIAL"        "CLAYER"           "CIRCLERAD"        "CHAMMODE"         "CHAMFERD"
"CHAMFERC"         "CHAMFERB"         "CHAMFERA"         "CENTERMT"
                "CELWEIGHT"        "CELTYPE"          "CELTSCALE"        "CECOLOR"          "CANNOSCALE"
"CAMERAHEIGHT"     "CAMERADISPLAY"    "CALCINPUT"        "BVMODE"
                "BTMARKDISPLAY"    "BPTEXTHORIZONTAL" "BPARAMETERSIZE"   "BPARAMETERFONT"   "BPARAMETERCOLOR"
"BLOCKEDITLOCK"    "BLIPMODE"         "BINDTYPE"         "BGRIPOBJSIZE"
                "BGRIPOBJCOLOR"    "BDEPENDENCYHIGHLIGHT"                "BCONSTATUSMODE"   "BACTIONBARMODE"
"BACTIONCOLOR"     "BACKGROUNDPLOT"   "AUTOSNAP"         "AUTOMATICPUB"
                "AUPREC"           "AUNITS"           "AUDITCTL"         "ATTREQ"           "ATTMULTI"
"ATTMODE"          "ATTIPE"           "ATTDIA"           "APERTURE"
                "APBOX"            "ANNOTATIVEDWG"    "ANNOAUTOSCALE"    "ANNOALLVISIBLE"   "ANGDIR"
"ANGBASE"          "AFLAGS"           "ACTUI"            "ACTPATH"
                "ACADLSPASDOC"     "3DSELECTIONMODE"  "3DCONVERSIONMODE" "3DDWFPREC"
(setq VarList '(0
                60
                0
                2
                0
                2
                50
                1
                0
                1
                0
                0
                5
                1
                0
                7
                3
                750
                5
                0
                0
                1
                0
                "ByEntity"
                "255,255,255"
                0
                1
                0
                1
                0
                "7"
                0
                0
                1
                -60
                -30
                0
                1
                1
                -6
                -2
                "ByEntity"
                1
                1
                1
                0.0
                0.0
                0.0
                0.0
                0.0
                0
                0
                0
                0
                0
                15
                0
                1
                1
                1
                3
                0
                1
                (* PI (/ 90.0 180.0))
                70
                1
                1
                1.0
                "*.autodesk.com;*.autodeskbutterfly.com;*.AutoCADws.com"
                1
                10000000
                3020
                0
                1
                1
                0
                0.05
                1
                0
                -8000
                1
                0.0
                "Standard"
                0.2
                50
                0
                1
                0
                1
                1
                0
                2
                1
                6
                6
                6
                6
                6
                1.0
                0
                2.0
                6.0
                0
                0
                2
                2
                60
                1
                1
                6
                8
                0
                127
                1
                1
                (QUOTE (0.5 0.5))
                0
                0
                0
                0
                (QUOTE (0.0 0.0))
                0.0
                6
                1000000
                3
                0
                0
                0.1
                1
                0
                1
                11
                0.0
                70
                3
                127
                3
                25
                1
                1
                1
                10
                1
                1
                1
                1
                1
                0
                1
                2
                20
                1
                20
                300
                0
                1
                1
                1
                0.0
                1
                0.25
                4.0
                1
                1
                1
                1
                1
                7
                2
                4
                0
                0.0
                90.0
                0
                2
                0
                0.0
                2
                0
                0
                1
                1
                0
                3
                1
                1
                5.0
                nil
                0
                0
                0.0
                0
                0
                0
                3
                0
                0
                2
                37
                0
                0
                3
                0
                2
                0
                -1.0
                0
                257
                0
                1
                1
                50
                50
                0
                4
                50
                0
                1
                "abc"
                2
                2
                "Internal"
                1
                1.0
                1
                1
                1
                0
                1
                0
                0
                1
                1000
                64
                1
                0
                25
                4
                2
                1.0
                -122.394
                0
                1500.0
                1.0
                2
                50.0
                65.0
                7
                1
                0.0
                0.0
                0
                0
                0
                (QUOTE (0.0 0.0))
                (QUOTE (12.0 9.0))
                0
                0
                0
                1
                50.0
                0
                2
                50
                15
                2
                1
                (QUOTE (0.0 0.0 0.0))
                8
                50
                1
                0
                257
                "Wireframe"
                "Realistic"
                "1"
                20
                1
                1
                1
                15
                "http://www.autodesk.com"
                0
                1
                0
                1.0
                0
                1.0
                0
                (QUOTE (0 0))
                10000
                "ANSI31"
                1000000
                0
                0.0
                3
                0
                1
                1
                0.0
                1
                1
                0
                0
                0
                0
                1
                1
                1
                5
                1
                100
                3
                1
                140
                160
                0
                (QUOTE (0.5 0.5))
                0
                5
                2
                1
                "acad.fmp"
                "simplex.shx"
                1
                0.0
                1
                31
                1
                0.5
                0
                1
                1
                0
                0
                0
                4096
                0
                0
                0.001
                0.698132
                1
                1
                0
                0.0
                0
                1
                1
                1
                0
                0
                3
                1
                31
                12
                1
                1
                2
                2
                3
                25
                10
                2
                1.0
                0.5
                8
                8
                3
                3
                3
                3
                4
                6
                12
                3
                3
                3
                3
                3
                8
                3
                3
                8
                3
                3
                3
                0
                0
                0
                0
                0.18
                "Standard"
                0.0
                0.0
                0.0
                1
                0
                1
                0
                0
                0.0
                0
                1
                0
                0
                1.0
                4
                0
                0
                0
                0
                0
                0
                1.0
                0
                0.0
                -2
                -2
                2
                0
                1.0
                0
                (* PI (/ 45.0 180.0))
                0.09
                0
                1.0
                0
                3
                0.0625
                0.18
                0.38
                0.0
                4
                1
                0
                0
                0
                0.09
                0
                0
                3
                0.18
                2
                0
                0
                2
                0
                2
                0.0
                25.4
                2
                0
                0
                1
                0
                3
                1
                1
                1
                0
                1
                2
                2
                5
                "Standard"
                0
                3
                0
                1
                0
                0
                "Standard"
                1.0
                0
                "Standard"
                20
                1
                1
                "ByLayer"
                "0"
                0.0
                0
                0.0
                0.0
                0.0
                0.0
                0
                -1
                "ByLayer"
                1.0
                "ByLayer"
                "1:1"
                0
                0
                1
                0
                1
                1
                12
                "Simplex.shx"
                "7"
                0
                0
                0
                8
                "141"
                1
                1
                1
                "7"
                2
                63
                0
                0
                0
                0
                1
                1
                1
                0
                0
                10
                0
                0
                -4
                1
                0
                0.0
                16
                6
                0
                1
                1
                2
                0
                60
                0
                2
                0
                2
                50
                1
                0
                1
                0
                0
                5
                1
                0
                7
                3
                750
                5
                0
                0
                1
                0
                "ByEntity"
                "255,255,255"
                0
                1
                0
                1
                0
                "7"
                0
                0
                1
                -60
                -30
                0
                1
                1
                -6
                -2
                "ByEntity"
                1
                1
                1
                0.0
                0.0
                0.0
                0.0
                0.0
                0
                0
                0
                0
                0
                15
                0
                1
                1
                1
                3
                0
                1
                70
                1
                1
                1.0
                "*.autodesk.com;*.autodeskbutterfly.com;*.autocadws.com"
                1
                10000000
                3020
                0
                1
                1
                0
                0.05
                1
                0
                -8000
                1
                0.0
                "Standard"
                0.2
                50
                0
                1
                0
                1
                1
                0
                2
                1
                6
                6
                6
                6
                6
                1.0
                0
                2.0
                6.0
                0
                0
                2
                2
                60
                1
                1
                6
                8
                0
                127
                1
                1
                (QUOTE (0.5 0.5))
                0
                0
                0
                0
                (QUOTE (0.0 0.0))
                0.0
                6
                1000000
                3
                0
                0
                0.1
                1
                0
                1
                11
                0.0
                70
                3
                127
                3
                25
                1
                1
                1
                10
                1
                1
                1
                1
                1
                0
                1
                2
                20
                1
                20
                300
                0
                1
                1
                1
                0.0
                1
                0.25
                4.0
                1
                1
                1
                1
                1
                7
                2
                4
                0
                0.0
                90.0
                0
                2
                0
                0.0
                2
                0
                0
                1
                1
                0
                3
                1
                1
                5.0
                nil
                0
                0
                0.0
                0
                0
                0
                3
                0
                0
                2
                37
                0
                0
                3
                0
                2
                0
                -1.0
                0
                257
                0
                1
                1
                50
                50
                0
                4
                50
                0
                1
                "abc"
                2
                2
                "Internal"
                1
                1.0
                1
                1
                1
                0
                1
                0
                0
                1
                1000
                64
                1
                0
                25
                4
                2
                1.0
                -122.394
                0
                1500.0
                1.0
                2
                50.0
                65.0
                7
                1
                0.0
                0.0
                0
                0
                0
                (QUOTE (0.0 0.0))
                (QUOTE (12.0 9.0))
                0
                0
                0
                1
                50.0
                0
                2
                50
                15
                2
                1
                8
                50
                1
                0
                257
                "Wireframe"
                "Realistic"
                "1"
                20
                1
                1
                1
                15
                0
                1
                0
                1.0
                0
                1.0
                0
                (QUOTE (0 0))
                10000
                "ANSI31"
                1000000
                0
                0.0
                3
                0
                1
                1
                0.0
                1
                1
                0
                0
                0
                0
                1
                1
                1
                5
                1
                100
                3
                1
                140
                160
                0
                (QUOTE (0.5 0.5))
                0
                5
                2
                1
                "acad.fmp"
                "simplex.shx"
                1
                0.0
                1
                31
                1
                0.5
                0
                1
                1
                0
                0
                0
                4096
                0
                0
                0.001
                0.698132
                1
                1
                0
                0.0
                0
                1
                1
                1
                0
                0
                3
                1
                31
                12
                1
                1
                2
                2
                3
                25
                10
                2
                1.0
                0.5
                8
                8
                3
                3
                3
                3
                4
                6
                12
                3
                3
                3
                3
                3
                8
                3
                3
                8
                3
                3
                3
                0
                0
                0
                0
                0.18
                "Standard"
                0.0
                0.0
                0.0
                1
                0
                1
                0
                0
                0.0
                0
                1
                0
                0
                1.0
                4
                0
                0
                0
                0
                0
                0
                1.0
                0
                0.0
                -2
                -2
                2
                0
                1.0
                0
                0.09
                0
                1.0
                0
                3
                0.0625
                0.18
                0.38
                0.0
                4
                1
                0
                0
                0
                0.09
                0
                0
                3
                0.18
                2
                0
                0
                2
                0
                2
                0.0
                25.4
                2
                0
                0
                1
                0
                3
                1
                1
                1
                0
                1
                2
                2
                5
                "Standard"
                0
                3
                0
                1
                0
                0
                "Standard"
                1.0
                0
                "Standard"
                20
                1
                1
                "ByLayer"
                "0"
                0.0
                0
                0.0
                0.0
                0.0
                0.0
                0
                -1
                "ByLayer"
                1.0
                "ByLayer"
                "1:1"
                0
                0
                1
                0
                1
                1
                12
                "Simplex.shx"
                "7"
                0
                0
                0
                8
                "141"
                1
                1
                1
                "7"
                2
                63
                0
                0
                0
                0
                1
                1
                1
                0
                0
                10
                0
                0
                -4
                1
                0
                0.0
                16
                6
                0
                1
                1
                2
(defun Once=>Init ( VALUELIST VARLIST)
  ;;(mapcar 'setvar VarList valueList);正确
  ;;(VL-CATCH-ALL-APPLY 'mapcar (cons 'setvar (list VarList valueList)));正确
  ;;(VL-CATCH-ALL-APPLY 'mapcar (list 'setvar VarList valueList));正确
  ;;(mapcar '(lambda (x y) (if (getvar x) (setvar x y)))  VarList valueList);正确
  (VL-CATCH-ALL-APPLY
    'mapcar
    (list
      '(lambda (x y)
         (if (getvar x)
           (setvar x y)
      VarList
      valueList
参与人数 2明经币 +2 收起 理由
434939575 + 1 这么多,辛苦了!
flytoday02 + 1 楼主这个怎么用啊~
本帖被以下淘专辑推荐:
发表于 2024-10-22 15:20:13 | 显示全部楼层
这个要收藏一下,以备不时之需
发表于 7 天前 | 显示全部楼层
谁有cad2019的呢?.scr
发表于 2013-1-23 13:48:27 | 显示全部楼层
07的和12版的
谢谢!!!  发表于 2013-1-23 16:29
发表于 2013-1-23 13:58:43 | 显示全部楼层
06机械版未见此文件
你未装ET工具  发表于 2013-1-24 12:24
发表于 2013-1-23 14:07:57 | 显示全部楼层
2006、2008、2010
谢谢!!!  发表于 2013-1-23 16:26
发表于 2013-1-23 14:37:25 | 显示全部楼层
楼上都补齐了。。谢谢分享!
发表于 2013-1-23 14:44:19 | 显示全部楼层
2013 64bit
你发的defaults.scr没了,能再发一次吗?  发表于 2013-3-1 10:42
发表于 2013-1-23 15:41:12 | 显示全部楼层
顶一个,期待楼主大作!
 楼主| 发表于 2013-1-23 16:27:40 | 显示全部楼层
诸位,2002  2009版的有吗?据查2000没有此文件
发表于 2013-1-23 22:04:48 | 显示全部楼层
谢谢!!!  发表于 2013-1-24 08:00
发表于 2013-1-24 11:42:05 来自手机 | 显示全部楼层
这个要顶……很好很强大
GMT+8, 2025-12-12 06:52 , Processed in 0.233384 second(s), 31 queries , Gzip On.
